VAG-COM (*New* section) Need some help with a VAG-COM? Have some good advice to offer others using a VAG-COM?
Rough Idle -- VAGCOM results inside
Old Nov 4, 2008 | 11:59 PM
pyropenguin's Avatar
Default Rough Idle -- VAGCOM results inside
The car isn't throwing any codes, I scanned block 003, 032 and I have no idea what these readings mean. Any ideas?
Block 032 --
Tuesday 4 November 2008
4B0 906 018 Q 1.8L R4/5VT G 0006
Group A: '032
At Idle Partial Throttle
TIME -10.1 -10.1
Marker STAMP % %
0.01 -0.8 3.1
0.49 -0.8 3.1
1.09 -0.8 3.1
1.69 -0.8 3.1
2.4 -0.8 3.1
3.05 -0.8 3.1
3.59 -0.8 3.1
4.19 -0.8 3.1
4.79 -0.8 3.1
5.39 -0.8 3.1
5.9 -0.8 3.1
Block 003 --
Thursday 4 September 2008 11:25:18
8D0 907 557 P 1.8L R4/5VT MOTR HS D04
Group A: '003
TIME
Marker STAMP
Tuesday 4 November 2008 20:38:58
Group A: '003
Idle speed Air Mass In Throttle Angle Ignition Angle
TIME 740-920 rpm 2.0-4.5 g/s 0.2-4.0% 0-12°BTDC
Marker STAMP /min g/s % °BTDC
449.43 0 0 5.9 0
449.89 0 0 5.9 0
450.49 0 0 5.9 0
450.99 0 0 5.9 0
451.66 0 0 5.9 0
452.28 0 0 5.9 0
452.85 0 0 5.9 0
453.39 0 0 5.9 0
453.99 0 0 5.9 0
454.59 0 0 5.9 0
455.18 0 0 5.9 0
455.69 0 0 5.9 0
456.28 0 0 5.9 0
456.88 0 0 5.9 0
457.48 0 0 5.9 0
458.08 0 0 5.9 0
458.72 200 1.44 3.9 3
Car is 2000 1.8t frontrack auto.
edit-
Block 114
Tuesday 4 November 2008 20:48:19
Group A: '114
Eng Load Call Corr. Load Engine Load Bypass Duty
TIME <=175% <=175% 15-175% Cycle
Marker STAMP % % % %
1009.69 85 83.6 100 0
1010.29 85 83.6 100 0
1010.87 85 83.6 100 0
1011.47 85 83.6 100 0
1012.07 85 83.6 100 0
1012.68 85 83.6 100 0
3.59 85 83.6 100 0
4.19 85 83.6 100 0
4.7 85 83.6 100 0
5.39 85 83.6 100 0
6.12 85 83.6 100 0
Block 002
Tuesday 4 November 2008 20:51:49
Group A: '002
Idle Speed Engine Load Inj. On Time Air Mass In
TIME 740-920 rpm 15-25% 2.0-4.0 ms 2.0-4.5 g/s
Marker STAMP /min % ms g/s
1220.18 0 100 0 0
1220.67 0 100 0 0
1221.26 0 100 0 0
1221.98 0 100 0 0
1222.62 0 100 0 0
1223.16 0 100 0 0
1223.77 120 67.7 2.05 0.78
1244.06 0 100 0 0
1244.66 0 100 0 0
edit--
Whoops, I'm sitting in this guys car right now trying to figure it out and i forgot to post why I'm logging all of this.
Basically in when you let the car idle the rpms fluctuate from ~800rpms to ~1300rpms and bounce up and down like that.
He posted a thread before and somebody said it could be the MAF or TPS, so I scanned block 003 for the TPS measure and 032 because this thread said it shows important stuff. []
HALP!
Old Nov 5, 2008 | 12:22 AM
Tweaked's Avatar
Stupid question I suppose, but did you try adapting the throttle body?
Old Nov 5, 2008 | 12:23 AM
...nope.
How do I do that?
nevermind, it's done.
Old Nov 5, 2008 | 12:36 AM
Tweaked's Avatar
Did it work?
Old Nov 5, 2008 | 03:27 AM
Yep, it worked!
thanks a lot!
Old Nov 5, 2008 | 09:51 AM
Tweaked's Avatar
Cool beans.
justinclarke
Nov 25, 2010 04:03 PM
Josche
May 21, 2008 12:19 PM
jshil
Oct 3, 2007 05:38 PM
