piggies and smog
Old Apr 11, 2008 | 02:54 PM
cbock's Avatar
Default piggies and smog
can somebody explain my options? i'm thinking about doing piggies but i expect i would fail smog. so how do you guys do it? do you swap out for piggies until it's smog time?
Old Apr 11, 2008 | 03:13 PM
i3uddha's Avatar
Site Moderator/Ninja
Default RE: piggies and smog
do a quick search under Piggies in teh b5 s4 section...
ull fail bec itll give off a CEL.
but there are ways around it - relocating the 2ndary 02 sensor etc. etc.
blah blah.
but technically messing w/ any of that "emissions" stuff is illeagal.
let me know if u have trouble finding the writeups etc.
Old Apr 11, 2008 | 03:46 PM
cbock's Avatar
thanks. i did a bunch of searching. found a lot of useful info about them. but, nothing that really answered my question. the only reference to smog if found was that it "may not pass inspection". if you're referring to this article, http://www.audiworld.com/tech/eng75.shtml, i've seen it and read it. but, what about the visual inspection at the smog test? won't relocated 02 sensors raise a red flag? and, thinking about it more. if it's a 8 to 10 hour job at ~$100/hr, that would be $2k to remove and reinstall for every smog check. doesn't seem worth it for what you get. i must still be missing something.
Old Apr 11, 2008 | 05:33 PM
Superdug's Avatar
SoCal Crew Member/White Devil
Well first off you gotta do it yourself to save cash secondly you have to make friends with your smog tech, and thirdly i have never really seen a smog guy climb under a car to make sure the o2 sensors were in the appropriate places.
Also by definition of the law making any modifications to your car at all is illegal. Technically when your first set of tires wear out and you have new one's put on that is a modification and according to the laws that is illegal. So really it's up to interpretation it always is. but I say do it and take your chances.
Old Apr 11, 2008 | 07:03 PM
cbock's Avatar
i would love to do it myself. however, i haven't had any practical experience beyond oil changes, replacing brake pads and a couple of fuel filters. and, i have no space at my apt to do it. and, if i have to make friends with the smog tech, i guess i better find another smog tech. :/
yeah, i've seen the whole modification arguement elsewhere. quite strange isn't it? lol.
so, basically, you're saying do it and i've got an excellent shot of having no issues. but, since i am not going to do it myself. will i have trouble finding a mech to do it?
Old Apr 21, 2008 | 01:16 PM
zippy_gg's Avatar
ORIGINAL: cbock
I had the same concerned and asked VAST the question. Below is the e-mail exchange. I hope this helps.
Gilles,
If you can pass the smog test now then installing the piggie pipes
should not effect that at all. Let me know if you need anything else.
Thanks,
Prince
Vast Performance
2430 Grayson Ave.
Ferndale, MI 48220
248-399-2222, Shop Phone
248-399-2223, Shop Fax
zippy_gg@yahoo.com wrote:
> I have a set of "PIGGIE-PIPES" in my shopping cart but before I buy and install I want to know if the "PIGGIE-PIPES" will make my A6 2.7t fail the smog check.
> Thank you!
> Gilles
Old Apr 21, 2008 | 05:34 PM
Superdug's Avatar
Sounds good to me. I want to get mine done f**k CA smog regulations.
Old Apr 22, 2008 | 02:20 AM
i3uddha's Avatar
ya you wouldnt fail bec. visually ur "stock" (now gutted) precats are still in their stock place.
& u wouldnt remove & reinstall anything.. ur using ur stock DP's.
the only issue would be in the relocating (read: welding)
of the o2 sensors so that their reading the right stuff. (after the cat)
so that they dont throw a CEL which would result in the smog test fail.
Old Apr 22, 2008 | 07:59 PM
Superdug's Avatar
Boo smog tests.
jasontkennedy
May 12, 2012 08:15 AM
DraxeofDclan
Dec 18, 2008 08:46 PM
CamoA6
Jun 17, 2008 05:26 PM
oshburg
May 14, 2007 07:36 PM
