Wheels and Tires Post up threads with questions about wheels and tires for your Audi here
98 A6 - can't get rear rotors/wheels on
Old May 22, 2013 | 07:25 PM
Melchizedek's Avatar
Default 98 A6 - can't get rear rotors/wheels on
So, I just got this car a little bit ago and am replacing the brakes. I got the front rotors and pads on and the wheels seem to go on (I haven't put them on yet).
I'm having real problems with the fronts. I have 17" stock wheels. The rotors I took of were the small ones, 9.63". The ones I got are the correct ones, 10.04"
I can barely get the holes to line up and when I try and put the wheel on I can't get anything to work for the lugs to go on.
Any help?
98 Audi A6 rear rotor - YouTube
Old May 24, 2013 | 04:45 PM
RGT's Avatar
RGT
those look like the wrong rotors, lay them down next to what you took off and I bet the offset is different. Not sure why you thought what you took off was the wrong size and went with a larger size? Looks like you need the smaller dia. ones.
Old May 30, 2013 | 03:50 PM
yeah, I know what you mean. I put small ones on and worked out fine. The dumb part is that the bigger ones are supposed to fit 17" wheels. so either the wheels I have didn't come with this car (even though the fronts fit fine), or they replaced the rear spindles and stuff. Lame.
snatchman
Aug 25, 2014 08:43 PM
drifter22
Jul 17, 2008 07:16 PM
IIQuArT
Jun 20, 2008 02:01 PM
pilot5.0
May 19, 2008 09:50 PM
freestyleski
Feb 21, 2008 11:24 PM
