Wheels and Tires Post up threads with questions about wheels and tires for your Audi here
can i use factory lug bolts with 5mm spacers???
Old Sep 8, 2009 | 06:41 PM
jsethwerner225's Avatar
Member
Default can i use factory lug bolts with 5mm spacers???
i just bought sum 19" rs4 wheels that are hitting my calipers in front, and upper control arm in rear. ive been told that 5mm spacers will fix this. there 45et offset wheels. can i use my factory lug bolts or do i need to buy longer ones?? and is it ok to go 5mm front and back, or should i go like 8mm in rear?? thanks in advance
Old Sep 8, 2009 | 09:41 PM
kiellish's Avatar
Member
i had some 19" wheels with a 45 offset and had 8mm spacers with them. definitely needed longer lugs for them, i would say you probably need some longer ones with a 5mm too.
kiellish's Avatar
Member
definitely make sure the spacers are hubcentric though, otherwise its a waste of money
Old Sep 9, 2009 | 12:42 PM
Member
do u think i should go with 8mm then??? ive noticed that only the 10mm and bigger have a hub built into them. the smaller ones are just flat and use ur factory hub sticking threw. that bad???
Old Sep 9, 2009 | 04:18 PM
kiellish's Avatar
Member
yea you will probably get a shimmy at speeds over 50 without hubcentric unless you are very careful when you mount them. i corrected my shake by centering the wheels by hand/eye, but it's a pain. just spend the $$ on hubcentric, it's worth it. if the 10mm hubcentric fits, do that, just get some lugs that are 10mm longer. make sure the seat is correct for the bolts, ball or cone, depending on your wheels.
Old Sep 9, 2009 | 06:16 PM
Member
ok ill try the 10mm. think im getting the forge motorsports spacers. im having a hard time seeing which kind of bolt these wheels need because the hole is so deep in them. the guy told me they were off an 08 audi rs4. but they dont have any audi emblems on inside so i duno if there replicas or what?? there 19's and they say ricambo italy, originale on the inside??? does that mean original equipment or something?? if they are reps, which bolts would i need? thanks for help and sorry for so many questions.
Old Sep 9, 2009 | 08:22 PM
kiellish's Avatar
Member
your stock wheels are ball seat, so take a look at the new ones and see if they look the same. also look at the lug bolts, see if the shape matches up. a cone seat will be like a cone, tapered smoothly. ask the people you get the spacers from to take a look at a wheel. if they are oe, my guess is they would be ball. either way, you need longer bolts if you're going to do spacers.
how much did you get the wheels for?
Old Sep 10, 2009 | 10:04 AM
Mike-2ptzero's Avatar
You can also go with a Wheel Stud kit. http://www.ringer-racing.com/product...&categoryId=37
Old Oct 7, 2009 | 04:20 PM
04B6V6's Avatar
jseth... what body are you running b5 or b6? 3.0 or 1.8? thank you im thinking about getting the 19x8.5 rs4 reps as well but these are only 38 offset should i be all set or need some space added as well?
chris95559
Aug 15, 2013 09:30 AM
randomloginname
Oct 16, 2008 10:03 AM
.clipse
Sep 24, 2007 01:32 PM
diehlryan
Jul 13, 2007 04:59 PM
foxrcng11
Feb 21, 2007 09:20 PM
