Wheels and Tires Post up threads with questions about wheels and tires for your Audi here
problem with tires
Old Mar 5, 2011 | 02:37 AM
jojosam's Avatar
Default problem with tires
i have a 2002 Audi A6 2.7t, Here's the problem:
The inside wall of the front two tires wear out realy bad, and i notice it that they have to be hitting something when i turn at 35+ mph. I took it to a tire place and they said that it was the alignment, but they did it, and the problem still there. When the car is not moving, the tires don't hit anything. I don't know if this is a common thing that happens to Audis. Does anybody knows?
Old Mar 5, 2011 | 08:50 AM
Miles@TireRack.com's Avatar
Has the A6 been lowered? Any time you lower a vehicle the negative camber increases although an alignment should identify that.
You may be due to replace some suspension parts like the shocks or springs because it's compressing too much which causes the rubbing. If you have the OE shocks on they have probably have had a good life and it's time to update.
Old Mar 5, 2011 | 03:02 PM
jojosam's Avatar
I've done Alignment and the mechanic said that it should be fine. The alignment is fine, but something is rubbing it when i'm driving it in curves. Yea, probably the springs or shocks, ha, thanks for replying, ill take a look at that. This is my second set of tires i'm going to put on my Audi.
I didn't know that a bad shock could do that.
needsmoreboost98
May 17, 2012 01:07 PM
DBK123
Aug 19, 2007 04:46 PM
backyard
Apr 6, 2006 12:06 AM
pindonesia
Nov 16, 2005 11:43 PM
jmerrell
Aug 25, 2005 04:01 AM
