Wheels and Tires Post up threads with questions about wheels and tires for your Audi here
running 5x114 wheels
Old Jun 16, 2013 | 08:33 PM
ThatRetardedKid's Avatar
Default running 5x114 wheels
Is it direct bolt with the hub?
Old Jun 17, 2013 | 12:04 PM
lance@tirerack.com's Avatar
Former Sponsor
The bolt pattern is only part of the equation. You'll need the center bore and offset or backspacing as well.
Thanks,
Old Jun 17, 2013 | 10:54 PM
Elaborate ok for example i saw a friend take a of set bbs lm off a acura tl and he said it was direct fit. So your saying that if a wheel with a pattern of 5x114, bore of 57.1mm and low enough offset so it doesnt hit it will fit?
Old Jun 18, 2013 | 07:58 AM
Former Sponsor
I would need to know the exact year, make, model, and trim level of car you have to get any more specific. Also, I can only offer fitment information in detail about the wheels we offer for sell. Most aftermarket wheels will require the use of centering rings for the hub. It isn't common that wheels are truly hub centric (no centering rings) and directly bolt on. There are some but not many.
@udikid
Mar 2, 2009 03:11 PM
tippman89
Mar 1, 2009 11:30 PM
Scott Long
Aug 31, 2007 08:43 PM
LuvmyAudi
May 31, 2007 11:21 AM
