Wheels and Tires Post up threads with questions about wheels and tires for your Audi here
Should I put 18" or 19" on my A4
Old Jan 29, 2011 | 01:55 PM
mono98's Avatar
Default Should I put 18" or 19" on my A4
Im shopping for new wheels an tires! but idk if i should put 18" or 19" even 20" what you guys recommend me? also i found the Nexen 7000 in a good price! How are they? im concern more in a quiet Ride thanks!
Old Jan 30, 2011 | 11:31 PM
sharper911's Avatar
I'd go with the 19's with low profile tires, but thats just my personal opinion.
Old Jan 31, 2011 | 02:38 AM
DÌEGØs AÜD!CTIØN's Avatar
are you lowered?
Old Jan 31, 2011 | 10:05 AM
mono98's Avatar
Thanx for the answer! well, no, not lowered, buy wheels is so hard! to many too choose! also the tires! i dont want to spend too much! but i want a smooth ride!
Old Jan 31, 2011 | 12:33 PM
carnutz's Avatar
Tires are the hard part! Good ones will cost you and crappy ones will make you crash!
Old Jan 31, 2011 | 03:43 PM
lower it first
Old Jan 31, 2011 | 09:12 PM
sharper911's Avatar
Although lowering looks great and improves handling, its not always practical. Everyday I have to drive over speed bumps at my school so I would bottom out if mine was lowered.
If you're wanting a new look for your car don't rule out the idea of just painting your existing rims. Thats what I did with mine and I love it.
Take a look at my pics if you want to see before and after
Old Feb 1, 2011 | 11:09 AM
Miles@TireRack.com's Avatar
mono98 it all depends on what you value. The 19'' is a catchier "look" and will improve the performance through steering responsiveness and control but in turn the ride quality will suffer since there is less tire sidewall to absorb the bumps in the road. The 18'' is just the opposite. More comfort and less sportiness.
Old Feb 1, 2011 | 04:50 PM
not necessarily. the wheel would have to be lighter to improve steering response & have the same offset as stock which I doubt it willl
and if by catchier look you mean negative attention because your car looks like its lifted on 18s then yeah thats about right
Old Feb 1, 2011 | 05:27 PM
If you kept everything equal, meaning the same tire with a shorter sidewall on the same but larger wheel diameter, there is no question that you would get a quicker steering response and an improvement in lateral stability. Less rubber = less flexibility. Unless you have invented a rubber compound with the stiffness of an aluminum alloy while maintaining grip and stickiness then this is bad information. I agree with you that an offset that keeps the wheel inside the fender well will help and that a lighter wheel will help but these are only secondary contributors comparatively.
As for the look - to each their own and God bless America!
