Wheels and Tires Post up threads with questions about wheels and tires for your Audi here
Which spacers should i get?
Old Oct 9, 2010 | 09:00 AM
richy's Avatar
Exclamation Which spacers should i get?
Guys i need some help and urgently. I tried reading through the forums but am having trouble finding a set up like mine. I ordered a set of 18" flat?fat fives for my b5 a4 quattro (prefacelift) which is currently running on bilstein pss9's(adjustable dampening and height). I need help figuring out which spacer would make the rim and tire sit flush with the fender. The rim has a e.t. of 45. I also ordered 225/40/18 Continental tires to match the rim. Please help me figure it out so that i can order some h&r ones of ecs. I'm hoping to get as flush as possible without having to roll the fenders. Thanks
Lazer viking ran 15mm up front and 20mm in back but he was using 205/40/18 iirc and therefore i might something different.
Old Oct 10, 2010 | 06:23 AM
richy's Avatar
Anyone, any help would be greatly appreciated
Old Oct 11, 2010 | 05:52 PM
pa4ul's Avatar
my rims are et 35. I run a 245-35-19 with 7mm spacers up front and 12.5 in the rear.
Old Oct 11, 2010 | 07:17 PM
richy's Avatar
thanks, i went off of lazer viking's setup since its the same rim, and got 15mm front and 20mm rear from H&R with matching bolts. If anything i can always roll the fender
Old Oct 18, 2010 | 09:36 PM
richy's Avatar
just to warn anyone that reads this, the flat fives fit almost perfectly flush without any spacers running 225/40/18 tires and the car sitting something like 24.75" gtf all around. I ended up sending back those spacers to ecs and ordered 5mm as they should be just right. et on these rims is 45 and width is 8.5" .
magnitude
B7 Models
10
Mar 8, 2012 12:06 PM
Mac_17
Feb 9, 2008 02:24 AM
ungawa
Jan 30, 2008 05:00 PM
EliteTuning1
Jun 21, 2007 09:04 AM
Mikefc626
Dec 12, 2006 03:43 PM
