Chop Shop Show off your designs here. Or post to have your fellow members do some photo shop work to your ride.
A8L tiptronic automatic to manual 6-speed 01E
Old 03-23-2024, 04:09 AM
glenbjackson's Avatar
just some weights on transmissions........
and got my star socket headed screws for the dual mass flywheel.......
last pics happen TONIGHT on my daily!
????Anybody rebuilding the auto transmission and needing that bearing you have to destroy to get to screws to remove the tail end??? it has a flange, is a roller bearing and i cannot find it anywhere. anybody know what im referring to and where i can find one?? or if no bodies making them, are any of you needing this bearing? i going to approach a local bearing manufacture and see if they'll make it.
ps on last post about the intake manifold flaps had me researching.
I was reading a ssp on the 4.2 and all that sludge that get in the intake manifold is because they imitate a "egr system" by pumping exhaust into intake tract. By overlapping intake valve on exhaust stroke even more. No externally plumbing or valves.... makes some sense. Just enough overlap for quantity of exhaust for next power stroke to pass emissions. kinda neat i thought so i shared
FATTY!!!
281lbs
155lbs
this was on my daily driver. im sure it was missed by myself smh didnt tighten it.
thread lock could have possibly prevented this. although not torqued, if installed with thread lock and even just finger tight would have still not loosened and not contacted the axle stub.
incorrect torque, wheel end vibrations and forward rotation of axle continuously unscrewed this screw clamping the wheel bearing.
  #32
Old 03-23-2024, 12:33 PM
twopedalwarrior's Avatar
I last posted in 2016 in this thread, and have been following it still for almost a decade. Keep it up man, ill buy you a beer when you've got'er done!
  #33
Old 03-23-2024, 10:06 PM
thanks for the motivation! hope im doing the same for someone out there.
this made me really smile bringing her home from storage.
Junkyard coolers should fit straight across inside rear bumper. Pedal cluster ready to go in.
For pistons I am going with gas ported top ring and a gapless 2nd I wanna try those. But I am looking for anybody with first hand experience with piston coatings?? Please let me know. Maybe creakote top and some thing on the skirts.??
  #34
Old 03-24-2024, 12:27 AM
I presume your asking about a ceramic coating on the pistons - not a bad idea. I've seen skirt coatings done rather often usually as a way to build up piston to wall clearance after a block has had a clean up hone. Had as much as .002' added back on to the skirts. Look into a fluropolymer coating. Ceramics aren't done on the domes to often. But only in extreme cases. If your tune is right, you won't need a top coat, as the proper mixture will keep the temps in check.
  #35
Old 03-29-2024, 02:27 AM
Default go anywhere luxury deserves go anywhere capacity
LOVE love love the ski-through in this car. I can bring 2x4s, 4x4s, long angle iron, all kinds of stuff makes D2 very capable. finally pieced together a rook rack from scrapyard. so now with added roof storage WOW this car becomes a comforting solution for cross country travel for sure. no bags in the cabin area, roomy CLEAN traveling setup. A recent break down made me realize ALWAYS have backup transportation(bike), tools and a hi-lift jack whenever traveling out of town and with heavy trucks ALL the time. Alot of thing can be fixed as long as you can get to a hardware/parts store or just off the road to gas. i didnt run out of fuel but a fuller tank helped a leaky pump pull enough fuel to get off road OR if your A8 has unusable last quarter tank issue!!!
abraidable coatings for clearance or slippery treatments for friction hmmmm let me see where the bores and pistons measure. For piston tops, i want to keep heat out so i gotta put something. if no testimonies ill try the home coatings and let y'all know.
  #36
Old 04-24-2024, 08:40 PM
Default another grand day.
i cannot speak for all limp modes and this is an event that i can't nor want to recreate so my best guess is all......here was my situation,
i was down shifting in manual mode to ascend a hill and my cluster showed limp mode (all ranges highlighted). I always thought i had to turn car off to get it to reset but i tried to put in neutral then back into drive, i felt the knotch/gate. i could feel and hear the transmission shifting, not making any odd noises, in a locate i could not pull over and on occasion shifting in manual mode would not register on the cluster. With all that in mind i decided to giggle side to side in the D and manual/tiptronic gate and it showed the correct D in the cluster and normal functioning resumed! MADE MY DAY. A nice little trick; bang it around like a manual till it works
i think some limp modes can be triggered by the selector switch in the gear shift lever not lining up/in-sync with the cable switch down on transmission. maybe the slight motion in between tranny, subframe and body adds up to relatively alot of motion and although the cable has slack it still moves enough in the chain to not match.
01E spacers should be here tomorrow, soon the matting of the two!! 6-speed plus 40 valves = appx. 120 speeds
jrdnsmthjrsm
03-22-2015 06:40 PM
A4QUATTRO727
03-13-2012 08:55 PM
southcoast
10-20-2007 02:01 AM
mainer
10-02-2005 01:18 AM
Quick Reply: A8L tiptronic automatic to manual 6-speed 01E
