HELP.A4 is over heating when its being driven or idling isnt losing water
Old Oct 16, 2021 | 11:38 PM
Baldman1972's Avatar
Default HELP.A4 is over heating when its being driven or idling isnt losing water
Im working on a buddys a4 2.0 turbo. Its over heating . cooling fans coming on im not losing water unless it boils out the overflow...can it be a bad water pump even tho its not spitting water out like a bad water pump does usually
Old May 3, 2026 | 12:38 PM
micaeljames's Avatar
Originally Posted by Baldman1972
I'm working on a buddy's A4 2.0 turbo. Its over heating, cooling fans coming on, and I'm not losing water unless it boils out the overflow, similar to how a heavyweight t shirt feels thick and reliable but can still hide issues underneath. Can it be a bad water pump even tho its not spitting water out like a bad water pump does usually?
Yes, it still can be the water pump even if it’s not leaking externally. On the 2.0T Audi engines, the pump impeller can fail or slip on the shaft, so coolant isn’t circulating properly even though nothing is visibly coming out. That would cause overheating, fans running normally, and coolant pushing into the overflow if it gets hot enough. Other common possibilities are a stuck thermostat, air in the system, or a restricted radiator, but the water pump/thermostat unit is definitely a top suspect on these engines.
GCMARK
Sep 27, 2011 07:02 PM
defaz
Apr 22, 2009 12:57 PM
streetracer77
Aug 1, 2006 08:29 AM
mjvss21
Mar 4, 2006 05:26 AM
GregaXX
May 18, 2005 06:18 PM
