Need to know what to start looking for.
Old Sep 7, 2008 | 09:54 PM
ceelos's Avatar
Member
Default Need to know what to start looking for.
Here are some recent codes I pulled. Thought someone on here might have been through some of these before and can tell me where I should start. Thanks in advance.
Address 01: Engine
Control Module Part Number: 4B0 906 018 M
Component and/or Version: 1.8L R4/5VT G 0003
Software Coding: 16201
Work Shop Code: WSC 13880
4 Faults Found:
16519 - Oxygen (Lambda) Sensor B1 S1; Heating Circuit: Malfunction
P0135 - 35-10 - - - Intermittent
17511 - Oxygen (Lambda) Sensor Heating; B1 S1: Performance too Low
P1103 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
17536 - Fuel Trim; Bank 1 (Mult): System too Lean
P1128 - 35-00 - -
Readiness: 0000 1000
Sunday,01,June,2008,22:06:01:10677
VCDS Version: Release 805.0
Data version: 20080529
Old Sep 7, 2008 | 10:07 PM
hiwords's Avatar
you're precat 02 sensor is dead, or you pulled the harness while the engine was running. clear the codes and see if any come back and post them. how does it drive? is your sig photochop? if not, you have like no tire lol
Old Sep 7, 2008 | 10:37 PM
ceelos's Avatar
Member
Nah, It's photo chopped lol, but the car is riding fine. This is the third time I pulled the codes. I cleared them today, but I'm sure they will come up again in a few miles. I puttin the order in for the O2 sensor now. It's probably dead like you said. Thanks again.
Old Sep 7, 2008 | 10:40 PM
hiwords's Avatar
you're 02 sensor is dead then. get a new one asap as that one hurts your gas mileage the most. autozone might have a bosch universal one where you can splice the wires in. that's wut i did at least. the OE is dumb expensive but it takes a bit longer with the bosch one
Old Sep 7, 2008 | 10:55 PM
ceelos's Avatar
Member
I hear ya, I already put an order in for a Bosch from ECS (Had the extra cash). I guess that explains the lean code as well. Thanks again for your help, it's much appreciated.
Old Sep 8, 2008 | 12:05 PM
SAudi's Avatar
i cant remember if i had the exact same codes but just quikcly see if fuse #23 is dead, i had soiem codes like that a while back with al my O2 sensors daed and the culprti was fuse #23
Old Sep 9, 2008 | 06:12 PM
ceelos's Avatar
Member
I looked at fuse#23 but it was good. It is a fuse for the side maker lights??? Is there another fuse #23 your talking about? Where would this fuse be? Just want to make sure.
Old Sep 18, 2008 | 07:59 PM
ceelos's Avatar
Member
Unhappy One fixed now new codes
Well.....I got the new sensor, installed it and reset the ecu. Drove the car for couple days and I get another cel. Here's what I got now.
Address 01: Engine
2 Faults Found:
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
P0116 - 35-10 - - - Intermittent
17704 - Error in Mapped Cooling System (check Temp-Sensor and Thermostat)
P1296 - 35-00 - -
Readiness: 0000 1001
Old Sep 18, 2008 | 08:17 PM
coleA4's Avatar
I would have gone with the universal its a tight squeeze trying to maneuver that harness through atleast on the 2.Greats
Old Sep 18, 2008 | 08:18 PM
coleA4's Avatar
Oh nevermind you already installed it. Double post.
Chito
Jun 28, 2010 08:48 PM
mark944turbo
Oct 10, 2005 05:51 PM
