2.0T Maintenance Intervals
I've searched the forums and looked through the Audi maintenance book to determine maintenance intervals, and there are some items that are not mentioned, or maybe they're typically done with something else. I'm sure Bentley has this info, but don't have one yet for my recently purchased CPO A3 with 26K.
So here's the list as I understand it, and I'd appreciate help filling in the blanks or correcting any errors.
2 yrs. Coolant
2 yrs. Brake fluid
20K Dust & pollen filter
35K Transmission oil (DSG)
35K Transmission filter (DSG)
35K Engine air filter
55K Spark plugs
75K Timing belt Should probably be 60K; at least that what I'll do
75K Serpentine (ribbed) belt
Fuel filter
Oxygen sensor
Water pump
Radiator hoses
I'm surprised that there are no replacement intervals called out for fuel filter or oxygen sensors.
Any experience with water pump or radiator life? Those are both considered wear items on all the BMWs that I know about. Pump impellers and/or bearings fail at about 60K, and radiator plastic necks (where the hoses attach) tend to get brittle at about 100K.
Any items I've missed, like CV joints and boots,brake hoses, or ?
2 yrs. Coolant
2 yrs. Brake fluid
55K Spark plugs
Fuel filter
Oxygen sensor
Water pump
Radiator hoses
RE: 2.0T Maintenance Intervals
I only have the info up to 55k.
Vehicle: 2006 Audi A3
At 5,000 Mi (8,000 Km) 3.2L 2.0L Turbo
Engine Oil / Oil Filter: Change the oil and replace oil filter. (Caution: 2006 Audi models use only engine oil conforming to VW 502.00 specifications). * *
Windshield Wiper and Washer / Headlight washer: Check adjustment and function check fluid level and add if necessary. * *
Tires and Spare Wheel: Check for wear and damage. Rotate tires. Check the pressure. * *
Wiper arm pivots: Lubricate. * *
Brake system: Check for damage and leaks. Check thickness of pads and brake fluid level. * *
Service Reminder Indicator Display: Reset the display. * *
At 15,000 Mi (25,000 Km) 3.2L 2.0L Turbo
use only engine oil conforming to VW 502.00 specifications).* *
Cooling System: Check coolant level. Add coolant if necessary. * *
Exhaust System: Check for damage and leaks. * *
Engine On-Board Diagnostic: Check Diagnostic Trouble Code (DTC) Memory. Purge if
necessary * *
Engine: Check for leaks. * *
Battery: Check electrolyte level. Add if necessary. * *
Dust and pollen filter: Replace. * *
Automatic transmission and final drive: Check for leaks. * *
Manual transmission and final drive: Check for leaks. * *
Sunroof: Clean guide rails and lubricate. * *
Wiper arm pivot points: Lubricate. * *
Tires and Spare Wheel: Check for wear and damage. Check pressure. * *
Tire repair set: Check renewal date. (Where applicable) * *
Service Reminder Indicator Display: Reset display. * *
Brake System: Check for damage and leaks. Check thickness of pads and brake fluid
level. * *
Front and rear axle: Check dust seals on ball joints and tie rod ends. Check tie rods. * *
Front and rear axle: Check excessive play. * *
Drive Shafts: Check boots. * *
Visual check: Check undercarriage for damage. * *
Road Test: Check braking, kick-down, steering, electrical, heating & ventilation
systems, air conditioning, Automatic Shift Lock (ASL) operation and power accessories. * *
At 25,000 Mi (40,000 Km) 3.2L 2.0L Turbo
Perform 5,000 Mi (8,000 km) Maintenance Service. (Except: rotate tires) * *
At 35,000 Mi (55,000 Km) 3.2L 2.0L Turbo
Engine Oil / Oil Filter: Change oil and replace oil filter. (Caution: 2006 Audi models use only engine oil conforming to VW 502.00 specifications). * *
Engine On-Board Diagnostic: Check Diagnostic Trouble Code (DTC) Memory. Purge if necessary * *
Dust and pollen filter for: Replace. * *
Wiper arm pivot point: Lubricate. * *
Doors: Lubricate door hinge mechanism. * *
Spark plugs: Replace * N/A
Brake System: Check for damage and leaks. Check thickness of pads and brake fluid level. * *
Haldex clutch: Replace oil. * *
Power steering: Check fluid level and add if necessary. * *
DSG (Direct Shift Transmission): Change fluid and replace filter element. * *
Lights: Check lights. Check Headlight adjustment. * *
Road Test: Check braking, kick-down, steering, electrical, heating & ventilation systems, air conditioning, Automatic Shift Lock (ASL) operation and power accessories. * *
At 45,000 Mi (72,000 Km) 3.2L 2.0L Turbo
THIS ENDS MAINTENANCE INCLUDED IN OPTIONAL MAINTENANCE PACKAGE
At 55,000 Mi (85,000 Km) 3.2L 2.0L Turbo
necessary * *
Air cleaner: Clean housing and replace filter element . * *
Service Reminder Indicator Display: Reset.
__________________
-dennis
Formerly dennisA4
Edit/Delete Message Reply With Quote Quick reply to this message
necessary * *
level. * *
necessary * *
__________________
-dennis
Formerly dennisA4
AFAIK, The fuel filter is supposed to last the "life" of the car. No specific intervals on the other items. However, it is always a good idea with a VAG product to replace the water pump with the timing belt change or you'll be doing it halfway through the life of the next belt. Always happens to me.[&:]
Cheers!
Cheers!
