audi a3 battery drain problem
Old 06-07-2009, 04:06 PM
auditomkins's Avatar
Default audi a3 battery drain problem
Hi,
The battery on my 2005 Audi A3 keeps going flat and the control panel (The bit that tells me the Average MPG, miles left in fuel tank etc) keeps going off and then comes on sporadically. The battery goes dead within a matter of days and I have resorted to disconnecting the battery now between using it. Can anyone help me?
Old 06-07-2009, 07:10 PM
4RINGSROD's Avatar
Sounds like a short some were I would take it in to get looked at.
Old 06-08-2009, 03:57 PM
Default Audi A3 Battery Drain
Hi, Thanks for reply. I thought this at first but put a multimeter between the positive on the battery and the positive connection and left it for a full day. It was only using 0.03Amp, which is a trickle charge to the alarm. When I open the doors and the internal lights it jumps up to 4+Amps etc... Another member has written to me and had a similar problem and it turned out to be the control panel in the dash, which when replaced solved the problem.
I am awaiting more info back from him but hopefully that will be the solution...although don't know the cost yet??? Any more advice that you can think off before I send it to Audi for what will be an expensive replacement....?
Old 06-08-2009, 06:50 PM
4RINGSROD's Avatar
Could be that your main screen that talks with the computer is all screwed up and needs replacement. That would require a look into the computer and either taking it to the dealer or a local shop to have it plugged in and looked at. Thats the only other thing I can think of. Good luck
Old 11-15-2012, 02:48 PM
audifluster's Avatar
My problem is identical. Did replacing the control panel fix the problem? That is what Audi suggested, but didn't guarantee. A pretty expensive fix....
nimmy
03-17-2015 07:53 PM
Rholly4
12-12-2014 01:51 PM
erubus
01-01-2011 01:53 PM
dan77
07-23-2010 02:57 PM
midwest_guy
08-16-2009 02:37 PM
Quick Reply: audi a3 battery drain problem
