TCM/TCU removal
TCM/TCU removal
Is there a DIY anywhere on how to remove the TCM/TCU (whatever you want to call it). I belive that it is under the carpet, by the passanger seat. I'm sure its a simple pull up the carpet and unplug the thing - I just want to make sure.
RE: TCM/TCU removal
Location of automatic Transmission Control Module (TCM) -J217-
The control module is located in front of the right front seat under the carpet in the foot well.
→ Fig. 19 Automatic Transmission Control Module (TCM) -J217-, removing and installing
[/ul]
Removing
‒Remove lower right A-pillar trim and right front door sill trim. [/ul]
Repair Manual, Body-Interior, Repair Group 70 " name=linktext> => Repair Manual, Body-Interior, Repair Group 70
‒Detach carpeting from right inside door sill, and raise carpeting approx. 20 cm.
‒Unclip box at -A- by pulling it upward.
‒Unclip box at -B- as shown. [/ul]
‒→ Unclip TCM from box (arrows).
‒Release catch on multi-pin connector and disconnect connector from TCM => Fig. 20 [/ul]
[/ul]
Removing
RE: TCM/TCU removal
Thanks - the link you gave us is to your job website - I assume since you have to work at a VW dealer to access it. I finally found the pictures and the removal guide in AESIS, dam that program is a PITA when your trying to find somthing.
