Sponsored by:
Sponsored by:
99 A6 TPS Codes With 2 O2 codes
Old 03-07-2013, 09:27 AM
Sammy~D's Avatar
Default 99 A6 TPS Codes With 2 O2 codes
I have a 99 A6 2.8 30v 220k AT Quattro.
I started the car yesterday and it would not stay running until I tapped the gas peddle and feathered it, then it would idle at about 250-300 rpm. No power under acceleration, and will not go over 30 mph.
I ran the codes and it came up with 3;
1. Throttle position Sensor
2. o2 bank 1
3. o2 bank 2
I understand that the TPS is not replaceable, that you are just better of buying a used throttle body. But a lot of the time it can be some other outlying problem.
I do not have a vagcom available to me at this point in time either.
Any input will be helpful
Sammy~D
Old 03-07-2013, 08:59 PM
TwinTurboC5's Avatar
Find someone with VagCom or have it diagnosed at a shop. I would try performing a throttle body adaption if you can find someone with the proper equipment.
markymarc
09-08-2010 01:59 AM
joenelson7687
08-25-2010 04:10 AM
Ruggedboy
07-20-2007 11:30 PM
supercoupe91
07-13-2007 06:20 PM
rafa_207
06-27-2007 01:31 PM
Quick Reply: 99 A6 TPS Codes With 2 O2 codes
