Sponsored by:
Sponsored by:
Engine light on ABS light on with Brake blinking...I have fault codes what do they mean
Old 07-31-2007, 12:49 AM
jasmix's Avatar
Default Engine light on ABS light on with Brake blinking...I have fault codes what do they mean
My engine light just came up so I had run diagnostics;
P1141
P0300
P0301
P0303
P1606
P1127
P1129
the mech said I have to change the Wire Harness burned caused due to coolant leak....labor costs around 1500.00 what do I do? what do these numbers mean
Old 07-31-2007, 08:51 AM
SilverGT's Avatar
Default RE: Engine light on ABS light on with Brake blinking...I have fault codes what do they mean
those are engine codes for the car. i dont know where u can get the engine code list for the audi if anyone has it i would also like to kno thanks.
Old 07-31-2007, 11:03 AM
jasmix's Avatar
I know that these are codes .how hard is it to fix these and how much will it cost?
Old 12-01-2007, 12:40 AM
This is just one of the pages for CODES
http://www.intendedacceleration.com/fault_codes.html
This page will have all codes for anything you can find wrong.
Great site for information.
http://www.bba-reman.com/content.asp...rary_obd2_eobd
P1141 Transmission Solenoid Valve 6
P0301 The pump motor
Old 12-01-2007, 03:17 PM
dankhound's Avatar
P1141-Abs system related fault
P0300 -misfires detected
P0301 -cylinder 1 misfire
P0303 -cylinder 3 misfire
P1606 -abs system related fault
P1127 -bank 1 fuel system too rich
P1129 -bank 2 fuel system too rich
You may want to start erasing all the faults and seeing which ones come back. Thats alot of faults to deal with. Those abs faults trip sometimes when the abs control module is bad. Check for faults in the abs thou.
Fuel system to rich faults are usually caused by bad mass airflow meters but could be caused by anything that would cause to little air or too much fuel to enter the engine. Misfires can be caused by an engine running on the very rich end. You could also have an ignition problem causing misfires.
HolyokeAudi
12-17-2014 09:13 AM
ady_m
10-16-2010 02:32 PM
insanoman85
04-12-2010 10:58 PM
fidelite
02-03-2009 11:04 PM
Quick Reply: Engine light on ABS light on with Brake blinking...I have fault codes what do they mean
