Left Rear Caliper
The caliper slide pins are frozen from rust. You can replace them or clean the up and grease them or get a new caliper. if you replace them make sure that you also replace the rubber covers and make sure they are seated properly to keep out water.
i too am experiencing trouble with my left rear brake. First, it seems that the outer edge of the rotor seems to be waring away while the inside is still fine along with my pads. Second my hand brake dose not go all the way down, and third, there seems to be a humming patter coming from that wheel swell. Could all this be related?
