Sponsored by:
Sponsored by:
Removing Steering Wheel
Old 04-29-2010, 07:19 AM
WoodShoe's Avatar
Default Removing Steering Wheel
I need to change out my signal stalk. Anyone have a diagram or steps in removing the steering wheel? Or if you have done it, possibly things I should be looking out for. THnx
Old 04-29-2010, 04:23 PM
hxgaser's Avatar
You will need long torx bits, and #10 or 12 triple square bits. Disconnect the battery, remove the 2 torx at the rear of the steering wheel to remove the airbag. Disconnect the electrical connectors and use triple square bit to remove the bolt holding the steering wheel. Make sure to mark the location of the steering wheel in relation to the column using a piece of tape. You may need a steering wheel puller, but mine came off without. Then there a several more screws and two more holding the column adjusting handle. You take the bottom cover off first and then the top comes off.
Old 04-29-2010, 05:06 PM
NH_USA's Avatar
I was not sure if the 2001 was the same as my 97 but it seems to be
Check this link for the discussion we had when I did the same thing.
https://www.audiforums.com/forum/sho...d.php?t=143294
Old 04-29-2010, 08:24 PM
WoodShoe's Avatar
Thanks guys, Ill try it tomorrow.
JustWondering
B7 Models
09-11-2011 11:17 AM
Josiah31
08-15-2011 09:30 PM
viper_04649
07-19-2007 01:16 PM
porscheslave
02-14-2007 08:14 PM
girlandscaping
07-04-2006 02:13 PM
Quick Reply: Removing Steering Wheel
