XENON HEAD LAMPS - Replacement options
My 2006 A6 Xenon headlamps are all hazed and look terrible.
I have been looking for replacements and oddly enough have not been able to locate anything with a cost of less than 800 each.
Anybody else have any luck in finding a source or replacement unit.
Don't want to go used because they might even look worse than mine.
thank you
peter
551.427.1178
pdachnowicz@gmail.com
thank you
peter
551.427.1178
There are several products on the market that polish and restore the plastic. Meguairs and Mothers sell them as kits. I generally use Meguiars Ultimate Compound to remove the worst of the haze (takes a lot of elbow grease) followed by their Plastic-X for the final cleaning and polishing. Then a couple good coats of car wax. Unfortunately, the haze is due to UV and will come back in 3-6 months depending on where you live, but if you wax the headlights frequently it helps. It's a lot cheaper than replacement, plus even new headlights will deteriorate due to the UV. Kinda makes you miss the old round glass headlights.
