Another will this rim fit question
Okay so im looking at Montegi Racing MR 118 there 18x8 with a 32mm offset i know thats cutting it close becouse from what info ive found you want 35 to 42 but it wasnt clear since the guy was talking about both 18x8 and 18.5s in the thread thanks. also is a 3mm spacer possible? And if it will fit what size rubber should i use?
I have 17x7.5's 42 offset with a 17.5 spacer so my final ET is 24.5.. I think you'll be just fine with a 32 offset. You'll be pretty close to flush probably. If you put a 3mm spacer that would put you at 29..
Someone correct me if I'm wrong...
Go with 225/40/18.
Go with 225/40/18.
akitamike
06-09-2008 11:05 AM
SouthernAudi
10-14-2007 06:47 PM
