Help.changed a few fuses and the transmission won't shift into second
Old 12-21-2005, 06:20 PM
porschefreek's Avatar
Default Help.changed a few fuses and the transmission won't shift into second
Yesterday i noticed that i had a tail light out and i went to check and see if the fuse was out..so next i changed the fuse with one that had slighty more amps then you should have..next my gauges wouldn't work because the fuse blew so i replaced it with another fuse with more amps..then when that broke i went and put the correct fuse into it's position..so i thought everything was ok but when i went to drive it the trasmission wouldn't shift into second.Help Help..i was thinking i might need to disconnect the battery to reset the computer..would that work?..transmission isn't broken but it just won't shift into second,third,or forth..it's my first car a 1995 audi a6
CIA
06-29-2008 01:19 AM
converted
05-08-2008 05:30 PM
Quick Reply: Help.changed a few fuses and the transmission won't shift into second
