Mechanics & Workshops Kudos and complaints equally welcome. Know a good one? Know a bad one? Advise/warn others.
crankshaft lock pin
Old 04-11-2017, 12:35 AM
spikkeman's Avatar
Default crankshaft lock pin
I'm trying to change my front crankshaft seal on my 2002 Audi Allroad Quattro 2.7 i cant seem to get to the area where you put the crankshaft lock pin in i can see where it goes but not sure how to get to it i tried a long extension with a socket but i cant get the socket on the bolt any suggestion and is it safe to remove the crankshaft bolt with the crank pin holding the crankshaft ? thanks mike
Old 04-11-2017, 04:26 AM
Jing Gao's Avatar
Hello mike, I also change my front crankshaft seal but don't know how to do it. Please kindly tell me if the problem has been solved by you.
Regards
Old 04-12-2017, 11:23 PM
spikkeman's Avatar
Jing Gao what I did was I took the 2 small bolts out of that big tube, that gave me the little added space I needed I use a 1/4 inch 10mm socket with 2 long extensions and a swivel , after I got the bolt out I then got the plug out with a long screw driver, I got the crank lock pin in by actually taping it to the 1/4 inch. 10mm socket ,after getting it in place I just left it their until I got my seals changed and the timing belt back on good luck
alinux
11-04-2008 03:11 AM
secmil
04-05-2007 11:45 AM
teru23
04-04-2007 10:52 AM
allwheelhead
01-14-2007 11:10 PM
Quick Reply: crankshaft lock pin
