Timing Chain or Belt???
Old Jul 28, 2009 | 08:15 PM
r1racer's Avatar
Default Timing Chain or Belt???
A have couple of newb questions.
1) on 3.2L 06 A6, is there a timing belt or chain?
2) is ih due for replacement at 75k?
3) is the V-belt/serpentine belt due for replacement at 75k as well?
4) what is the avg cost for a timing belt/serpentine/water pump service?
5) how often do you change transmission fluid on this vehic;e and avg cost?
Thanks!
Old Jul 29, 2009 | 12:06 AM
hxgaser's Avatar
3.2 FSI is timing chain, not belt. So no replacement is needed. V-belt is usually good until 100K.
I can't comment on the water pump service, but as for the transmission fluid and filter change, a dealer the stealer will charge you somewhere in the $500 range. Indy tech will charge you around $250 to $300.
Old Jul 29, 2009 | 09:41 AM
r1racer's Avatar
Thanks again hax. But one more newb question. Do all of the 05/06 (i think it's C6 models) have 3.2 or 4.2 "FSI" engines or are there other types of engines with a timing belt?
Old Jul 29, 2009 | 11:30 AM
hxgaser's Avatar
As far as I know, all C6 3.2 are FSIs with timing chains. I am not quiet sure about the 4.2s though.
Old Jul 30, 2009 | 06:51 AM
Kevin's Avatar
The 4.2 in the C6 has a timing chain. The 4.2 did not go with FSI until 2007.
Old Jul 30, 2009 | 07:51 AM
r1racer's Avatar
So all c6 models from 05 on up have chains that don't need replacement? Also are the 4.2l engines known to have problems like engine slum and oil leaks? Finally, reliability wise, is there any difference between the 4.2L & 4.2L FSI? Thanks for the info.
Audiguruforyou
Sep 20, 2011 01:31 AM
B72.0tsline
B7 Models
Mar 3, 2009 01:18 PM
xX|05:A4|Xx
May 3, 2008 08:28 AM
CTDriver
Mar 19, 2008 10:19 PM
blown540
Jan 5, 2007 08:56 AM
