Help - no front brakes!
Old Jul 24, 2004 | 09:40 PM
ChrisB's Avatar
Default Help - no front brakes!
I bought my '98 about a month ago and was happy about how new and perfect the front brakes look. Now I just realized why - the front brakes aren't receiving any pressure during braking. I found out when I painted over the rust that was on the rotor hub and I oversprayed onto the rotors. After driving a couple of days the front rotors still had paint where the brake pads should've been rubbing! The rears are doing all the work. It shows - the rear rotors are really worn. During normal driving I didn't really notice anything wrong. Anyway, I'm used to older cars with proportioning valves, but with ABS I'm a novice. Anyone have any ideas where I should start looking? I have no desire to have a dealer take advantage of me unless I have no other options. Thanks in advance...
Old Jul 24, 2004 | 11:01 PM
ImolaS4's Avatar
Default RE: Help - no front brakes!
This sounds very odd. You painted your rotors??!!
The pads should have sensors that will keep the ecu notified of any brake changes - you don't have any warning lights?
How many miles are on the car?
Old Jul 24, 2004 | 11:13 PM
ChrisB's Avatar
Yes, I painted the rusty part of the rotor where it meets the wheel (no pics - sorry). Some paint oversprayed onto the rotor.
Only the airbag light is on - planning on getting a VAG-COM soon to work on that.
Old Jul 24, 2004 | 11:14 PM
ChrisB's Avatar
Just turned 100k on the odometer but by the way the rears look, it's been this way for quite a while.
Old Jul 24, 2004 | 11:30 PM
ImolaS4's Avatar
Sounds to me like you'll need to do a complete overhaul of the front pads and check the calipers to see if they are functioning properly. This will mean R&R with a hands-on approach and eye-balling the parts directly. I'd inspect the lines, too.
Old Jul 24, 2004 | 11:41 PM
ChrisB's Avatar
I originally thought the same thing, but what are the chances that both front brake calipers would stop working at the same time? Do you think that the ABS module could be bad? I know that I'm being an armchair mechanic at this point, but I'm just trying to figure out where to start troubleshooting.
Old Jul 25, 2004 | 12:00 AM
ImolaS4's Avatar
ORIGINAL: ChrisB
Yeah... it's possible, but you should have an ABS warning light that would have alerted you. At least some sort of CEL should have come up. But hey... it's worth checking.
Do you have access to a VAG-COM? That should help with the initial DX.
Old Jul 25, 2004 | 12:21 AM
ChrisB's Avatar
I don't have a VAG-COM yet. I've been trying to learn about it. Do you recommend the $229 kit that Ross-Tech sells? Not sure exactly what I need or want.
Old Jul 25, 2004 | 04:51 PM
ImolaS4's Avatar
It depends on your budget and how fast a laptop processor you have.
If you have questions, you can always ask them at Ross. They are a bunch of really cool people - I've met them in person at their house and they were really super people.
Old Jul 25, 2004 | 05:16 PM
David_K's Avatar
yikes!
BPEvans12982
Sep 29, 2013 02:59 PM
xristos.greece
Mar 11, 2010 09:08 AM
braeden
Apr 17, 2008 03:46 PM
vincemazzocco
Nov 26, 2006 06:05 PM
KylesA4
May 15, 2006 09:18 PM
