Excessive front tire wear on '00 S4
Old Apr 20, 2006 | 10:07 PM
ballistic69's Avatar
Default Excessive front tire wear on '00 S4
I purchased an '00 S4 in October '05 and had to replace the tires after 1600 miles. I purchase a set of 4 Kumho 712 at NTB and had a 4 wheel alignment performed. After 3 months (January '06) I started to notice tire noise. The front tires are wearing excessively on the inner and outer shoulders, the center has normal wear. I took the car back to NTB and had the car realigned, tires rotated and pressures checked. Now, 3 months later, I am still having the same problem. Has anyone else experienced this problem and do you have a solution?
Kirt
Old Apr 20, 2006 | 10:48 PM
shelby69's Avatar
Default RE: Excessive front tire wear on '00 S4
A lot of 'alignment shops' can't correctly align an Audi. There is a special tool to set the camber on our cars. Seems like alot of shops just set toe. I'd make sure that the tires are not under-inflated (good tire gauge) and take it to an Audi dealer to align.
Old Apr 22, 2006 | 03:06 PM
dankhound's Avatar
Definatly sounds like an underinflated tire.
Old Apr 22, 2006 | 08:01 PM
The tire pressures have been checked and rechecked weekly. It is not a tire pressure issue.
Old Apr 22, 2006 | 08:04 PM
techbod's Avatar
equal wear on inner and outer is low tyre pressure
Old Apr 22, 2006 | 08:06 PM
techbod's Avatar
without any doubts what pressures are you putting in there "min" 30 psi
Old Apr 24, 2006 | 06:46 PM
AudiS4_190's Avatar
yea it def. sounds like underinflation.
Old Apr 24, 2006 | 06:55 PM
S4sweeteeteeRS's Avatar
had kuhmo ecsta ASX on the A6. tires wore terrible on inside. had to replace after about 10,000 miles. will NEVER buy kuhmo's again.
Old Apr 24, 2006 | 07:22 PM
The tires that are currently on the rear of the car were on the front and showed the same wear. They were run with 40 psi. The tires that are on the front are run with 35psi. I know for a fact that this is not a tire pressure issue.
This is an alignment issue, but according to NTB the car is in spec. I guess I will have to take it to the Audi "Stealer" and see if they can correct the problem.
Old May 7, 2006 | 11:59 AM
rogue2's Avatar
How did this work out for you ballistic? I experienced the same problem with my car and just put on four new tires + alignment. I too KNOW that this is not an air pressure problem, as i am obsessive about checking it.
Since i had this work done by Big O my ride seems rougher. Could be i am over sensative but i don't think so. I sware I am getting a rithmic vibration at about 75 to 80 mph. I am thinking of taking It back in to have them rebalance the wheals.
ttfn,
Matt
niedz
Nov 18, 2014 06:42 AM
noahjackson
Dec 21, 2011 12:10 AM
ppgoal
Jul 26, 2010 12:13 PM
mberthia
Nov 18, 2006 01:17 PM
