Climate control gone bad
Old Dec 19, 2004 | 05:26 PM
boffin58's Avatar
Default Climate control gone bad
I was just wondering if anyone out there knows why my climate control is playing up?
Its a 1996 audi A4, Basically the heat selection works fine, but when you desire heat/cold at the dash mounted vents, it aint having none of it. All though the feet and the window settings are fine.
Anyone know? thanks
Old Jan 25, 2005 | 10:54 AM
yakatar's Avatar
Default RE: Climate control gone bad
Did you find an answer for this one, I have an A6 1996 with a similar problem in that I can get hot and cold to the face vents but not to the screen or floor, as it is all electronic don't know where to start
Old Jan 25, 2005 | 07:01 PM
Jestnomen's Avatar
6th Gear
I think there is a blower flap motor that can go out, or the climate control unit is bad and not sending the appropriate signals.
Old Jan 25, 2005 | 10:26 PM
yakatar's Avatar
My first thought was the Facia Control Unit but don't want to start a 'Lets spend lots of cash swapping bits out till it works' scenario. Second thought was the servo motors but them would they all go, tis possible.
Have now found out how to interrogate the Climate Control System and look at the fault codes and it returns the following
08.5 - Temperature Regulator Flap static block
11.7 - Central flap sporadic block
13.7 - Footwell/Defroster sporadic block
15.4 - Air Flow Flap Motor Potentiometer sporadic short
Not looking good [sm=smiley6.gif]
Old Sep 24, 2005 | 09:51 AM
ciciair's Avatar
Hi I have a 96 a4 i.8 similar problem intermitant fault with climate control somketimes its stays on heat and will not go to cold and some time stays on cold will not go to heat but fan modulates up and down automaticly will like any information that you might come across will appreciate greatly or info how climate control works I am an electrician from Sydney Australia
Old Feb 1, 2006 | 08:29 AM
alanpemma's Avatar
Hi How do interigate the climate control for fault codes cheers alan
Old Dec 15, 2007 | 03:33 AM
ciciair's Avatar
Hi I have a 96 a4 i.8 problem intermitant fault with climate control somketimes its stays on heat and will not go to cold and some time stays on cold will not go to heat but fan modulates up and down automaticly will like any information that you might come across will appreciate greatly or info how climate control works I am an electrician from Sydney Australia Lately has stuck in heat position it sonds like a flapper motor stuck if so where is location .thanks[align=right]
[/align]
AnthonySlaughter
Aug 3, 2014 07:27 PM
a8audiv8
Apr 13, 2007 05:33 PM
cian_ie
Jan 10, 2007 07:07 PM
02A4
Mar 27, 2005 10:42 AM
