Climate control gone bad
I was just wondering if anyone out there knows why my climate control is playing up?
Its a 1996 audi A4, Basically the heat selection works fine, but when you desire heat/cold at the dash mounted vents, it aint having none of it. All though the feet and the window settings are fine.
Anyone know? thanks
Anyone know? thanks
Did you find an answer for this one, I have an A6 1996 with a similar problem in that I can get hot and cold to the face vents but not to the screen or floor, as it is all electronic don't know where to start
My first thought was the Facia Control Unit but don't want to start a 'Lets spend lots of cash swapping bits out till it works' scenario. Second thought was the servo motors but them would they all go, tis possible.
Have now found out how to interrogate the Climate Control System and look at the fault codes and it returns the following
08.5 - Temperature Regulator Flap static block
11.7 - Central flap sporadic block
13.7 - Footwell/Defroster sporadic block
15.4 - Air Flow Flap Motor Potentiometer sporadic short
Not looking good [sm=smiley6.gif]
Hi I have a 96 a4 i.8 similar problem intermitant fault with climate control somketimes its stays on heat and will not go to cold and some time stays on cold will not go to heat but fan modulates up and down automaticly will like any information that you might come across will appreciate greatly or info how climate control works I am an electrician from Sydney Australia
Hi I have a 96 a4 i.8 problem intermitant fault with climate control somketimes its stays on heat and will not go to cold and some time stays on cold will not go to heat but fan modulates up and down automaticly will like any information that you might come across will appreciate greatly or info how climate control works I am an electrician from Sydney Australia Lately has stuck in heat position it sonds like a flapper motor stuck if so where is location .thanks[align=right]
[/align]
[/align]
chattyboy
Sep 4, 2009 02:11 PM
