Busted glove box...
Old May 10, 2007 | 10:48 PM
skrammoof's Avatar
Default Busted glove box...
Ok, I've been trolling around this forum for a while now, finally decided to register. Anyway, I'm having some issues with my damn glove box. (car is a 2003 A4 1.8t Quattro) Basically I have a feeling something is broken with the latch...when I try to pull the handle, there's no resistance like it's not actually connected to anything, and there's a damn rattle coming from the box whenever I drive. Wouldn't bother me too much cause I never use the box...except for the rattle. Driving me crazy.
Just curious if any of you guys have ever had a similar issue or have any idea how to fix this. I've tried prying it open and the left side (where the handle is) seems to be able to move freely, but the right side is firmly locked in place and I don't want to bust it any more than it already is. And...I did try to search, but that appears to be broken right now [:@]
Oh, and since I'm sure some of you want to see what I have, here's a pic of the car (not the best pic, but oh well)
Old May 11, 2007 | 04:45 AM
AteUrV8's Avatar
Default RE: Busted glove box...
mine rattles too, it sucks
Old May 11, 2007 | 07:25 AM
skrammoof's Avatar
yes, it really does. I'd love to not have to go in to the dealer and have them look at it, but it appears that may be the way to go...
i should start being really buddy-buddy with those parts and service guys...maybe i could start getting the hook-up or something
Old May 11, 2007 | 08:49 AM
Sarah7106's Avatar
LOL...........that's my plan be buddy-buddy. I chatted up the service manager while I was buying my Audi cause I already knew they were going to have to fix the glove box so I was talking about it with him.
Anywho about the rattling.......mine rattled this morning but only when the bass blasted. So I'm pretty sure the rattling is something I have inside my glove box. I'm getting a new one anyway so even if this one is having rattling problems I'll have a new one hopefully by monday.
Old May 11, 2007 | 01:14 PM
auditech79's Avatar
The problem with B6 an on A4 glove compartment are the door hinge on the right side, if you open the glove compartment door you will probably notice a crack where the right side hinge is, this will also make it harder to close the door because its not aligned properly. To fix this youjust replace the door, remove the glove compartment by removing all the 8mm nuts, about 10 of them and pull the glove box door downwards. Use a wire cutter tool and a hammer to bang out the door hinge pins, then use a small T8 torx to remove the screw for the handle on the door and pop out the lock. Install in reverse order, anyone with a B6 or newer A4 should check the hinge because they break quite frequently.
Old May 11, 2007 | 01:58 PM
Sarah7106's Avatar
ORIGINAL: auditech79
Yup the right side hinge is what is broken on my glove box. I didn't do it so they're gonna fix it but it sounds like I may run into this issue again a little later down the road.
Old May 12, 2007 | 11:52 AM
VitaminB6's Avatar
Had mine replaced once under warranty. The fact that they didn't squawk about it at all and had the part in stock told me this was a common problem.
Old May 13, 2007 | 04:05 AM
skrammoof's Avatar
Um...thank you! Gotta love it when you're supplied with such a detailed answer. Greatly appreciated. I'll have to get myself a new door ASAP and give this a try. I damn near tore the whole thing off on my way home this evening...stupid rattle just about drove me nuts. Also, on the subject of rattles, I also appear to get a slight buzzing from time to time coming from the Map and door light/sunroof **** area...anyone else have an issue with this?? I read a little bit of info about it sometimes coming from the light sockets up there...just thought I'd see if any of you guys/gals had any thoughts or experience with that.
And thanks again.
Old May 13, 2007 | 05:23 AM
AteUrV8's Avatar
i just put some double sided thick tape in between that little crack on the left side, works wonders.... oh ya, but leave the white stuff on theside that touches the box or else it will stick lol
Old May 13, 2007 | 06:09 AM
skrammoof's Avatar
Dope. Thanks bro.
soundguy
Apr 2, 2012 09:23 AM
B7Night
B7 Models
May 22, 2011 03:09 AM
ARIaudiS4
Dec 13, 2007 01:21 PM
Team Loco
May 22, 2006 04:42 PM
TheJazz7
May 25, 2005 08:59 AM
