Can someone point me in the right direction?
Old Aug 31, 2007 | 11:51 PM
kickasS4's Avatar
Default Can someone point me in the right direction?
I was wondering if there was a DIY for the front stock bumper conversion to an RS4 from a B5 S4.
Old Sep 1, 2007 | 01:57 PM
2k S4's Avatar
Default RE: Can someone point me in the right direction?
Tools, dremal, scredrivers, knife, bondo, glazeing compound, epoxy,sandpaper, primer, paint
3 RS4 center grills
1. Pull out old grills
2. Pull bumper
3. Remove the stock grills from the holders. There are little tabs that have been plastic welded, grind them off.
4. Remove the - from the grill holders, I used a dremal with a plastic cutting wheel. Get up really close so the bulge is gone.
5. Sand around the area, back sand, both sides about 2in.
6. Find the - that you cut, remove a little to use as a backing for the hole. Epoxy that piece to the back of grill holder
7. Fill in the area with Bondo
8. sand the bondo down smooth, fill in with the glaze, resand
9. Paint the grills.
10. Line up the RS4 grills so they are uniform across all 3 pieces.
11. cut the grills to fit, epoxy them in place, trim of all the access. There will be a slight gap at the top of the side grills.
12. Reassemble entire bumper.
13. Stand back & admire your hard work.
Old Sep 2, 2007 | 12:43 PM
kickasS4's Avatar
amazing write up 2K, i will be starting that up this week. How did you blend the paint in so well? how exactly did you do it? thanks again
Old Sep 2, 2007 | 12:58 PM
2k S4's Avatar
I paid a shop to repaint the whole front bumper, so it's perfect!
Old Sep 2, 2007 | 02:35 PM
kickasS4's Avatar
ah got it, i will have to look around for a good one. thanks again
Old Sep 2, 2007 | 03:35 PM
mattr7786's Avatar
wow 2ks4 that is amazing i love it....i like that look way better then the actual rs4 front bumper ..yours looks so clean..[sm=icon_cheers.gif]
fredct
Jun 16, 2015 10:57 AM
Joshanlou
Sep 16, 2011 05:31 PM
teeebagTOM
Jul 25, 2009 08:59 PM
Schank
Feb 16, 2009 11:10 AM
Terry36
Mar 7, 2008 12:58 AM
