E/BRAKE LIGHT
Old Apr 5, 2008 | 09:48 PM
gmudan's Avatar
Default E/BRAKE LIGHT
Hi guys, i need so advice on a problem that i got , after parking the A8 2004 for the winter , i have the e/brake light on, but after applying the brake and pulling up the switch for the emergency brake , a couple of times the light goes out.....any suggestions.
Old Apr 27, 2008 | 09:43 AM
ImTheDevil's Avatar
Default RE: E/BRAKE LIGHT
The e-brake cables (or the e-brake portion of your rear brakes) may be binding up, since the car sat for so long. You might try pulling the wheels off and spraying down everything with brake cleaner. On the A8 I am not sure if the e-brake is built into the caliper assembly, or if the rear brakes are a combination disc/drum (disc for driving, with a drum e-brake). If it's the former, you may be able to take care of it by giving the whole caliper/brake assembly a bath with brake cleaner, and maybe trying to lube the e-brake cables. If it's a drum e-brake, you could pull the rotor and see about freeing up any seized components inside. Note though, that if you're going to park it for extended time periods, you may be better off not using the e-brake, so that it doesn't seize up on you like that. Of course, you run the risk of it seizing up in the released position as well, but in any event, as you drive the car more, it may clear itself up through usage.
Old Apr 28, 2008 | 09:15 PM
gmudan's Avatar
Thanks ,but the problem was a bad caliper, it was under warranty so the dealer will replace it.....i asked to get both replaced but will see ..thanks anyway.
fidelite
Feb 3, 2009 11:04 PM
blanthony
Mar 25, 2006 01:18 PM
