TCU location/removal?
Old Aug 29, 2008 | 04:03 PM
jaymac's Avatar
Default TCU location/removal?
This is separate from the ECU, correct? Just asking as I'm looking into the VAST tip chip and know I'll need to remove the TCU.
I did "search" first, but the engine won;t recognize TCU as a search term...
Thanks guys,
Jeremy
Old Aug 29, 2008 | 04:06 PM
oc_audica's Avatar
it's under the passenger side under the carpet
i'll see if i can find the instructions i think they're on AudiWorld
...edit...
found it
http://www.audiworld.com/tech/eng38.shtml
Old Aug 29, 2008 | 05:17 PM
jaymac's Avatar
Perfect- thanks!!
Old Aug 29, 2008 | 05:58 PM
formulagigi's Avatar
very easy. Did it several times in under or about 30 Minutes.
Vast has instructions they can email you too. Ask kurt or prince. Prince can even walk you thru the process on the phone. Email me if you have trouble with it. A6biturbo@gmail.Com
Now you should expect the possibility of braking one to all of the tabs on the metal box that contains the TCU once you've bent them once to open the box. No buggy. You can use electrical tape for example to hold it more secure but it is in a bigger plastic box anyway. Enjoy the chip.
Old Aug 29, 2008 | 11:48 PM
wammy18's Avatar
Hardest part is getting under the carpet :-X!
pgk
Mar 24, 2023 06:26 AM
cmg
Audi Q7
Apr 12, 2013 04:19 PM
99a4wagon
Dec 10, 2010 07:03 PM
boyne
Sep 30, 2010 05:23 PM
carlv
Apr 21, 2008 12:30 PM
