86 5000S fuel distributor
Old Oct 3, 2006 | 06:00 PM
bearddee's Avatar
Default 86 5000S fuel distributor
Car will not start if the electrical connection to the fuel distributor is connected, the one faceing front toward headlite. After I start the car, with the connector off, the engine will not rev very high maybe 3000 RPMs and won't go over 30 MPH when in gear. If I reconnect the electrical connection at this point the engine runs fine till it gets warm, then it will not idle it just stalls. If I try to restart it won't work unless I remove the electrical connection. Need a little help. Thanks Ron
Old Oct 4, 2006 | 01:15 AM
InExile's Avatar
Default RE: 86 5000S fuel distributor
check here for more info http://www.sjmautotechnik.com/troubl...ing/ficis.html
Old Oct 6, 2006 | 12:38 AM
0fframp's Avatar
I doubt that the problem is with the fuel distributor, check for vacuum leaks and the coolent temperature sensor.
mariaudi
Sep 6, 2007 02:33 PM
TurboRhatt
Feb 21, 2007 04:45 AM
flyund83
Jul 26, 2006 10:45 PM
bearddee
Jul 14, 2006 05:15 PM
WickedPete
May 7, 2006 12:41 AM
