86' CoupeGT digital instrument cluter
The car has a digital instrument cluter which is malfunctioning .... gets really realy bright -> dimms -> goes out compleatly -> comes back on again ... when it comes back on again all the trip comp info is reset
1. Bad wireing ?
2. Instr Cluster itself is toast?
3. Other?
Does any one know anything about these Instr Clusters and would a mechanical one be plug and play .. I suspect that it sould be..
Thanks
1. Bad wireing ?
3. Other?
Thanks
Check the connectors going to the gauge cluster and the interconnections on the cluster, most likely that is the problem. Also check the solder joints for any cracks a.k.a. cold solder joints.
Hey, just bought an '87 Coupe GT. The person who owned it before us described a similar issue, but now the instrument cluster is not working at all. Only the accessory lights. We took it all apart and checked all wiring and connectors and solders and fuses that relate to it. Still not working... anymore ideas?
The Instrument Cluster was fixed/replaced by the dealer when the PO had the car. Now the prob is reoccurring. When the dealer fixed it, I know that the odometer was started from 000000 there is a sticker in the door jam that says that ... so the fixing might be a PITA, but I don't now for sure. I haven't looked at my IC yet .... but I think that replacing it with a mechanical IC (with needles and guages) would be the easiest and most efficent fix
Well I would assume so b/c the accessory lights on the cluster are working, but other than that I don't even know how to tell. The fuses for it are good, even though they weren't blown, we still changed them. Any ideas??
take the cluster itself apart and really look at all the pins and connectors ... use a microscope if need be .. look close at all solder joints try resoldering them ... i've heard that there is a manual for that cluster .. try asking a dealer for one the manual might give some pointers..
stephan949
Feb 9, 2006 06:44 PM
