94 Cabriolet - wet carpet rear passenger floor
Old Sep 20, 2006 | 01:05 PM
bobbh's Avatar
Default 94 Cabriolet - wet carpet rear passenger floor
I have a severely wet rear passenger carpet after it rains. I've pulled the carpet up and dried out the pad (It's amazing how much water the pad can hold!!!) I left the carpet and pad up and sure enough, after a good rain, there is water laying at the lowest point, where the back seat platform meets the floor. All other areas in the car, including the trunk are dry.
I could really use some help on where to look to solve this problem.
Thanks,
BH
Old Sep 20, 2006 | 06:04 PM
kakarot's Avatar
Default RE: 94 Cabriolet - wet carpet rear passenger floor
probable the door leaks, just check the molding for being good, and the way I do it, is put toilet paper near the points that may be leaking, if they leak the toilet paper would be weat.
Old Sep 20, 2006 | 06:11 PM
techbod's Avatar
most common leak
[IMG]local://upfiles/12092/62AFACD4DC0E4279886475ECB2712C41.jpg[/IMG]
Old Sep 20, 2006 | 06:54 PM
kakarot's Avatar
yep that what I mean, around the door and the window, there is the rubber things, could be them.
Old Sep 21, 2006 | 12:06 AM
bobbh's Avatar
Thanks folks... I'll give it a shot. I was thinking that there might be some sort of drain plug that is clogged...
I'll check the seals.
Thanks,
BH
reminthorn
Jan 7, 2015 06:06 AM
akricer
Aug 20, 2011 03:25 AM
jaimea6
May 15, 2008 10:30 AM
jaimea6
May 14, 2008 03:55 PM
