audi 100-problems-HELP PLEASE!
Old Apr 27, 2007 | 05:33 PM
j4n3k's Avatar
Default audi 100-problems-HELP PLEASE!
I had allready posted about my problem i didnt get any response. I posted that my 2.3e 100, is having idle problems when starting the engine ( hot or cold ) then after 5min it idles fine. I also think that the fuel consumption is a little high. Its not the isv and i have no vacum leaks and elec...conectors are in god shape. How can i test the air intake valve ( I think that is called air intake valve right? ). I also noticed that when the car is started for the first time ( In the morning) It smokes and run rough for a minute or so. Could this be a problem with the spark????
Thank you for your advice.
Old Apr 28, 2007 | 03:06 AM
InExile's Avatar
Default RE: audi 100-problems-HELP PLEASE!
double check on thevacum leaks .... also take a look at the injectors
Old Apr 28, 2007 | 10:21 AM
j4n3k's Avatar
A mechanic checked the vacum pipes all ok. How do i ckeck the injectors?
Old May 1, 2007 | 05:06 AM
InExile's Avatar
drive till nice and warm ... remove plugs after 30 mins if you see gas in the cyl you got a problrm .... or jerk the injectors and check the spray pattern
Old May 1, 2007 | 07:34 AM
techbod's Avatar
it could be a few things but the high fuel consumption brings that down to 2 items ( cold start valve and differential pressure on the fuel regulator ) but then again it could be the IAC
Idle speed control
[ul][*]Idle speed control devices are all fitted into a throttle by-pass system, allowing extra air to enter the engine. This extra air complements the mixture enrichment during a cold start and the subsequent warm-up period.[/ul]
Idle air control (IAC) valve - Fig 10
[ol][*]The auxiliary air valve allows air to by-pass the throttle valve when the engine is cold, to increase idle speed during the warm-up period.[*]Bi-metal strip[*]Heating element[*]Valve plate[*]By-pass air[/ol]
Old May 1, 2007 | 07:37 AM
techbod's Avatar
[IMG]local://upfiles/12092/A6159FE21E204762B8A50E1D530BAF4C.jpg[/IMG]
Old May 1, 2007 | 07:15 PM
j4n3k's Avatar
tnx for the advice.
But if there was something wrong with the iac valve or cold start valve the car would only have problems to idle when cold right? The problem is that it doesent matter if the car is cold or hot. If i drive let say for a half an hour and turn the car off and then on again it will idle up and down for 3 min. What is differential pressure? and how do i know if its ok?
hpelyno
Feb 2, 2015 06:33 AM
wd56
Jun 7, 2013 12:41 PM
Smokin Tubes
Feb 5, 2012 10:11 AM
ckaae
Dec 16, 2008 03:59 AM
marc2023
Nov 10, 2006 03:22 AM
