AUDI 90, 1991
Old Oct 9, 2005 | 07:21 AM
tom2005's Avatar
Default AUDI 90, 1991
Hi:
Does any one know if AUDI 90, 1991 needs to change timing belt?
I am interested in on very cheap AUDI 90, 1991. The owner told me that this car use another method and has no timing belt. it is ture?
Thanks,
Old Oct 9, 2005 | 04:07 PM
rhibdrivr's Avatar
Default RE: AUDI 90, 1991
unless someone swapped in a Wankel or turbine or something, the car has a timing belt.
Old Oct 9, 2005 | 05:10 PM
kakarot's Avatar
I believe you can drive it untill the belt goes, then just replace it and drive some more.
correct me if I'm wrong, thoughs engines are non intefiring 4 cyl >1.8L and 5 cyl
Old Oct 9, 2005 | 08:39 PM
tom2005's Avatar
Hi:
Thanks for the answers.
but does it need to be changed??
Please see the link: http://yarchive.net/car/timing_belt.html
Also, in the 1991 models (Audi maintenance), it indicated:
Additional Vechicle Maintenance every 90,000 miles
-- Toothed belt: Replace (Audi V8 only)
So 1. is the toothed belt = timing belt?
2. does it mean that other models in 1991 (except V8) donot need to change timing belt??
thanks,
Old Oct 9, 2005 | 10:57 PM
kakarot's Avatar
1. YES
2. No, it means if on V8 or V6 belt goes valves are beaned and would need a lot of repairs. for 4 and 5 cyl if belts goes you will be straineded some where
Lomax57
Aug 8, 2010 10:56 PM
Tony B
Mar 16, 2009 10:33 PM
Audi20091
Aug 21, 2008 11:46 PM
gball30593
Apr 24, 2008 09:55 AM
travisn
Dec 11, 2006 11:13 AM
