cv joint kit vs axle shaft
Old Oct 25, 2007 | 11:57 AM
apalmer's Avatar
Default cv joint kit vs axle shaft
hi guys...have an 88 audi 90 5 banger
needs front outer cv joint....
now i have found axle shafts that seem to have all the parts needed for 65-70 dollars a piece....and cv joint kits for 135.00...
a little confused...does the axle shaft not have the complete cv joint (only the axle side?)
also think i need the abs sensor...some cv joint kits claim to inlude the sensor...but the sensor sold separately is about 168.00
any help would be appreciated
Old Oct 25, 2007 | 12:10 PM
Reckless_Kelly's Avatar
Default RE: cv joint kit vs axle shaft
The complete axle assemblies are usually rebuild (don't be scared). while the CV joint kits are brand new. I personally would rather put in a rebuilt axle and save a s@#tload of money than have to go through removing the CV joint from the axle, and then knowing that the other end has X miles on it. Most of the rebuiltaxles come with a longer warranty anyways.
Old Oct 27, 2007 | 12:22 AM
InExile's Avatar
^ i second that
Old Oct 27, 2007 | 10:16 AM
AbingtonJim's Avatar
The outer CV joint wears 3-4 times faster than the inner and can be replaced without removing the full axle assembly. Not that difficult a job and takes 1-2 hours to do.
Old Oct 29, 2007 | 12:10 PM
AWDaholic's Avatar
Senior Administrator
^^ IDK, getting that outer joint off took an AWFUL lot of banging, three grown men taking turns WHACKING-AWAY with various-sized hammers/mallets, and that was WITH teh axel off teh vehicle. I'm told there is some sort of tool for accomplishing that process much, much easier. maybe you should look into what it is and if you can buy/rent one...
Audilaw
Oct 14, 2010 06:11 PM
jinsojoo
Nov 11, 2009 05:59 PM
bow129
May 14, 2009 04:54 PM
sautsinaga
Feb 29, 2008 04:57 PM
