Allroad Model Line Audi's take on the modern "Crossover" of a sport utility vehicle and a station wagon
Air suspension control module location
Old Aug 25, 2011 | 10:53 AM
vtraudt's Avatar
Default Air suspension control module location
Where is the air suspension module located?
How can it be removed?
From VAGcom scan: is this the part number of the module?
4Z7 907 553 B
Old Aug 25, 2011 | 05:29 PM
myaudi98's Avatar
In the rear usually to the right of your air tank. Kinda hard to get to.
There is a write up somewhere about changing it. Cant remember where though. Sorry.
Old Aug 25, 2011 | 06:26 PM
vtraudt's Avatar
Haven't found the air tank yet, but had the compressor and the valve block out.
I am referring to an electronic module (if there is one), NOT the valve block with the solenoids.
Somewhere (I doubt it is done in the ECU), the inputs from the 4 height sensors, pressure and temperature sensor, and inputs from the dash selector switch and vehicle speed have to be processed.
Old Aug 26, 2011 | 10:23 AM
myaudi98's Avatar
Look in your trunk. On the right side should be a compartment with your bose system if you have one. on the left side another compartment with your jack. Underneath it is the air tank. To the right of it is all the electronics for the air suspension, ECM
certan
May 24, 2020 07:06 PM
cucas
B7 Models
Apr 28, 2014 08:55 PM
pconn171
Jul 24, 2012 12:08 PM
jrward
Dec 21, 2007 08:37 AM
JDriver2
Jul 10, 2006 11:16 PM
