Allroad Model Line Audi's take on the modern "Crossover" of a sport utility vehicle and a station wagon
Help with error codes. VAG Com VCDS
Old Dec 24, 2013 | 03:37 PM
ceccorp's Avatar
Default Help with error codes. VAG Com VCDS
Hello I finally figured out how to get my VAG com to work.
I ran a scan and got the following codes. Could someone please help me figure out what I need to replace and fix based on these codes?
Chassis Type: 4B - Audi A6 C5
Scan: 01,02,03,06,08,15,16,17,18,22,34,35,36,37,45,55,56 ,57,65,67,75,76,77
Address 01: Engine Labels: 078-907-551-AZA.LBL
Controller: 4Z7 907 551 K
Component: 2.7l V6/5VT G 0001
Coding: 06752
Shop #: WSC 02325
VCID: 4BE9E42F6ADD
WAUYP64B01N050184 AUZ7Z0Y1567513
11 Faults Found:
17862 - Exhaust Gas Temp Sensor 1 (G235): Short to Ground
P1454 - 35-00 - -
17866 - Shareware Version. To Decode all DTCs
P1458 - 35-00 - Please Register/Activate
16684 - Shareware Version. To Decode all DTCs
P0300 - 35-00 - Please Register/Activate
16685 - Cylinder 1: Misfire Detected
P0301 - 35-00 - -
18010 - Shareware Version. To Decode all DTCs
P1602 - 35-10 - Please Register/Activate - Intermittent
17539 - Shareware Version. To Decode all DTCs
P1131 - 35-10 - Please Register/Activate - Intermittent
17521 - Oxygen (Lambda) Sensor; B1 S1: Internal Resistance too High
P1113 - 35-10 - - - Intermittent
16502 - Shareware Version. To Decode all DTCs
P0118 - 35-10 - Please Register/Activate - Intermittent
17956 - Shareware Version. To Decode all DTCs
P1548 - 35-10 - Please Register/Activate - Intermittent
16689 - Cylinder 5: Misfire Detected
P0305 - 35-00 - -
16688 - Shareware Version. To Decode all DTCs
P0304 - 35-00 - Please Register/Activate
Readiness: 0010 1101
Address 02: Auto Trans Labels: 01V-927-156.LBL
Controller: 4Z7 927 156 A
Component: AG5 01V 2.7l5VT USA 1414
Coding: 00002
Shop #: WSC 00000
VCID: 44FBCF134783
1 Fault Found:
17125 - Torque Converter Clutch: Stuck OFF / No Power being transferred
P0741 - 35-00 - -
Address 03: ABS Brakes Labels: 8D0-907-389.LBL
Controller: 4Z7 907 389
Component: ABS/ESP allrad D47
Coding: 06397
Shop #: WSC 02325
VCID: 09651E272021
1 Fault Found:
01435 - Brake Pressure Sensor 1 (G201)
27-10 - Implausible Signal - Intermittent
Suspension and Wiper Electronics Scan Gets Error:
No response from controller
Address 01: Engine
Protocol: KW1281
Coding: 06752
Shop #: WSC 02325
Protocol: KW1281
Coding: 00002
Shop #: WSC 00000
Protocol: KW1281
Coding: 06397
Shop #: WSC 02325
Address 08: Auto HVAC
Protocol: KW1281
Controller: 4B0 820 043 K
Note: Excessive Comm Errors
Address 15: Airbags
Protocol: KW1281
Controller:
Address 17: Instruments
Protocol: KW1281
Controller: 4Z7 920 980 B
Component: C5-KOMBIINSTR. VDO D13
Coding: 02264
Shop #: WSC 02325
Address 1A: Unknown Address: 1A
Protocol: ????
Controller:
Note: Can't Synch Baud Rate
Address 25: Immobilizer
Protocol: KW1281
Controller: Bit teA dre ssu
Component: e 17 eingeben
Address 33: OBD-II
Protocol: ????
Controller: OBD-II/EOBD, Protocol Keyword: $0808
Address 34: Level Control
Protocol: KW1281
Controller: 4Z7 907 553 Bîu
Component: - 2C1A1 X031
Coding: 25500
Shop #: WSC 00000
Address 35: Centr. Locks
Protocol: KW1281
Controller: 4B0 962 258 J
Component: Central Lock/Alarm D33
Coding: 15885
Shop #: WSC 02325
Address 55: Xenon Range
Protocol: KW1281
Controller: 4Z7 907 357
Component: dynamische LWR D04
Coding: 00030
Shop #: WSC 02325
Address 56: Radio
Protocol: KW1281
Controller: 4B0 035 195 A``
Address 7E: Ctrl Head Dash
Protocol: KWP2000
Controller:
Tecnic91687
Aug 28, 2014 09:28 PM
Tecnic91687
Aug 14, 2014 03:46 PM
tofast2belast
Mar 2, 2013 07:37 AM
tilhas
B8 Models
Dec 9, 2011 11:51 PM
Lude
Nov 12, 2009 09:05 PM
