Allroad Model Line Audi's take on the modern "Crossover" of a sport utility vehicle and a station wagon
Help! Trying to remove engine/tranny bolts on 2.7T Allroad
Old Jun 2, 2009 | 06:09 PM
jeffski1's Avatar
Default Help! Trying to remove engine/tranny bolts on 2.7T Allroad
I am trying to replace the clutch on my 2.7T Allroad. I am having much difficulty figuring out how to remove the bottom three allen head bolts that face forward. Bentley manual makes it sound soooo easy--just lift the tranny a little and remove. Ya right. I can't seem to get enough clearance over the sub-frame. Am I not jacking it up enough maybe? It feels like I am about to start lifting the whole front end of the car up if I jack it up any more and my tranny jack is only rated for a 1/2 a ton. Can I remove or disconnect the subframe? That seems like a bad idea. Any ideas?
Also, Bentley only mentions 2 allen head bolts to remove but I see three on mine. I there a difference in A6 2.7T trannys and Allroad 2.7T trannys maybe?
Thanks
Old Jun 2, 2009 | 06:32 PM
jeffski1's Avatar
I found this tip on another forum:
"Three bolts under the tranny blocked by the subframe - Undo both side motor mounts, shave down an allen wrench (i chopped it off with an angle grinder) to get to the front motor mount, jack the motor up with one jack, jack up the tailshaft of the transmission (after removing the 2 transmission mount nuts!), remove the sway bar. Easy access with an allen wrench socket with a small extention on a rachet now by going around the subframe."
What a pita. Bentley conveniently left all of that out of their manual.
Is there a better way?
Old Jun 2, 2009 | 08:46 PM
jeffski1's Avatar
Well, I think I found the answer. Looks like I need to remove the motor mounts in order to lower the subframe to get the clearance I need to get at the bolts. I wonder why the Bentley manual doesn't mention this? I hope I not doing something wrong. But I don't see any other way.
Old Jul 8, 2012 | 09:17 AM
blitzin247's Avatar
I just had this same problem, glad I found this. I thought about the subframe route too.
Old Jul 10, 2012 | 10:01 PM
aspen79's Avatar
That is how we do it at work. Unbolt the engine and trans mounts, and lower the subframe down. This is with a engine support bar up top to hold the engine and a post jack under the trans tailshaft on a hoist but you get the idea anyways.......I agree, those 3 bleepidity bleep allen head bolts are a PITA even with all the tools and equipment!
midnightride42
Apr 21, 2013 11:21 AM
DOC_DEPALMA
Oct 21, 2010 06:47 PM
Zachariah
Sep 27, 2010 12:01 AM
JoeyVee
Mar 12, 2007 12:37 PM
eness_rx7
Dec 26, 2006 05:50 PM
