Allroad Model Line Audi's take on the modern "Crossover" of a sport utility vehicle and a station wagon
Suspension locked, ABS and ESP flashing.
Old May 26, 2007 | 11:30 AM
handyandy's Avatar
Default Suspension locked, ABS and ESP flashing.
Hi,
I have an Allroad 2.5TDI, 2000, recently the car was serviced, during the time the car was up on ramps, the garage ownersteam cleaned the worshop with the car up in the air, on picking the car up the dash would not light up. To cut a long story short after removal of the ECU which was full of moisture, drying the ECU the car came back to life,the only faults remaining is the one i,ve listed,
Please can anybody help with this, all replies greatly appreciated.
Regards,
Andy
Old May 29, 2007 | 09:03 AM
myaudi98's Avatar
Default RE: Suspension locked, ABS and ESP flashing.
I would say get a lawyer. That is crazy. Check your manual and go to part where you jack up the car. Maybe if you reset the suspension, it will reset the others. I had all three lights on when the car was cold one day. -12 to be exact. But after it warmed up it was ok.
Old May 29, 2007 | 05:09 PM
handyandy's Avatar
Thanks myaudi98,
I,ve tried to reset, i can hold both buttons in to lock or unlock the suspension, bothgreen lights illuminate for the up and down,but the jack mode lights still says on.
Is there a way of checking if the ecu is shot.
Regards,
Andy.
Old May 31, 2007 | 09:14 AM
myaudi98's Avatar
See if anybody around you has a vag com and maybe they can reset the lights and see if they come back on.
Josh Matthew Williams
Jul 9, 2020 06:58 PM
prescue
Feb 20, 2011 12:00 PM
mack010s4
Nov 30, 2010 10:07 PM
bilney1
B7 Models
May 27, 2008 03:10 PM
