2001 B5 1.8 Main Bearing damage--Moved to B5 forum--
Old Apr 10, 2008 | 10:19 PM
daveck2's Avatar
Member
Default 2001 B5 1.8 Main Bearing damage--Moved to B5 forum--
I bought this 01 A4 1.8 with Auto last week not knowing why it was not running. It turned over but wouldn't start. Upon further inspection, I found 3 camshaft caps that were pretty worn due to lack of oiling and so I pulled the oil pan (PITA) to check and see if I need just a new head, or a bottom end too.
So far all the rod bearings look great but there is one Main Cap bearing that is scorned pretty bad. The crank looks good and the cap is fine, just the bearing looks terrible. See picture below
Can/should I just replace the main bearing and put a new head on it or should I replace the whole engine? I was planning on flushing the engine a few times to remove any debris from the oiling system before running it. The car only has 74k mile on it and I hate to spend all that money if I don't have to.
What do you guys think, are these engines tough and will it recover with new bearings, or should I start over?
Audi Owner for 1 week and counting.......Need motor
[IMG]local://upfiles/51471/CEE55CEDEB554348926DDB5B006281E5.jpg[/IMG]
Old Apr 10, 2008 | 10:24 PM
daveck2's Avatar
Member
Default RE: 2001 B5 1.8 Main Bearing damage
Sorry, I just realized I posted to the wrong forum.
Admin, can you kindly move this post to the Audi B5 1.8 Tech forum?
Thanks
Old Apr 10, 2008 | 10:38 PM
beem's Avatar
I would want to find the cause for the oiling problem first. It is a lot of workand costlyto rebuild an engine having rebuilt a few of them myself. I would look for a good used engine first. B.
JoeBink
Apr 18, 2012 05:55 PM
firebirdvr4
Jul 28, 2009 05:56 PM
firebirdvr4
Jul 28, 2009 03:16 PM
daveck2
May 17, 2008 09:06 AM
daveck2
Apr 15, 2008 04:48 PM
