F/S Reman Close Ratio 6 speed trans
Old May 24, 2008 | 08:12 PM
scotty@advauto's Avatar
Banned
Default F/S Reman Close Ratio 6 speed trans
I've got a custom close ratio 6 speed trans. Great for a lower et at the strip. Thethird gear allows less of an RPM drop keeping your engine in the powerband when you need it.
Ratios are as follows:
[ul][*]3.50 first [*]1.89 second [*]1.42 third [*]1.07 fourth [*].86 fifth [*].73 sixth [*]4.11 Final Drive[/ul]
All updated parts were used, the 1st and 2nd gear surfaces are cryo treated and micropeened/polished. Shift collar sliders are anti-friction coated as well as bearing surfaces. This trans has the wide first gear and a 6 month limited guarantee.
I can also build a trans to spec. Feel free to browse my website at www.advancedautomotion.com.
If you have a core 6 speed I can deduct $600 off the price of this transmission.
If you have a core 5 speed I can deduct $200 off the price. I cover shipping on the return transmissions.
Old May 25, 2008 | 12:25 AM
10SecS4's Avatar
Default RE: F/S Reman Close Ratio 6 speed trans
Pretty cool, what are 3-4 and 5-6 from, an Allroad?
The big problem with the S4 trans is 1st is way too short and 2nd is way too long, causing a huge RPM drop and bog on the 1-2 shift. Any solutions for that one?
Old May 26, 2008 | 02:36 PM
Banned
Since the 1st and second gears are integral to the mainshaft, we are stuck with what was offered by the factory, unless 10people can pony up the 3-4 grand it will cost to have a custom mainshaft and 1st and 2nd gears machined as one off pieces. The only ratios avaiable are 3.50 first with a 1.89 second or a 3.75 first with a 2.06 second.
That 3rd 4th combo in our close ratio 6 speeds are from a TDI gearbox.
Another viable option is to go to a final drive ratio of 3.89. We offer that as an option to all our transmissions.
Old May 26, 2008 | 06:51 PM
10SecS4's Avatar
So the Allroad uses the same 3rd and 4th at the TDIs? Because the ratios are identical...
With the shorter gearing, most Stage 3 S4s would have to make the extra shift to 5th going down the strip, so I'm not sure how ideal that would be. Man, what I really want is a close ratio box with different 1st and 2nd gear ratios!
Old May 27, 2008 | 09:04 AM
e8myshrts's Avatar
ORIGINAL: 10SecS4
You and me both, however we're stuck with the ratios that Audigave us.
Old Jun 4, 2008 | 12:43 PM
Banned
ORIGINAL: 10SecS4
With enough money a mainshaft and matching gears can be manufactured, but your talking big bucks. Barring very deep pockets your stuck with what Audi has offered, a 3.75 1st and 2.09 second or 3.50 first and 1.89 second.
Old Aug 4, 2008 | 04:41 PM
Banned
check out what these guys have to offer. Very tight ratios, and very expensive.
http://www.vsmotor.no/en_index.html
95,000 Norweigan Krone = 18,700 usd.
However with that tight of ratios you'd be going through 6 gears on the strip.
02A4q
Nov 10, 2014 02:47 PM
dhmgejs
B8 Models
May 28, 2013 12:42 AM
cyberdude
B8 Models
41
Jan 3, 2013 08:23 PM
shady927
May 2, 2010 05:46 PM
MickeyD
Dec 2, 2009 10:49 AM
