i need a 1.8t motor for a 00 A4
Old Mar 29, 2006 | 12:01 AM
kloepfer_3's Avatar
Default i need a 1.8t motor for a 00 A4
aight i need a motor i just found out i blew my head gasket or pistons. i found oil with the sparks plugs.
Old Mar 30, 2006 | 08:46 PM
quattrosedan's Avatar
Default RE: i need a 1.8t motor for a 00 A4
what are you doing with your original engine? Where do you live?
Old Mar 31, 2006 | 03:18 AM
kloepfer_3's Avatar
i dont know..... i need one first or if anyone on here can help my on fixing this problem so i dont have to buy a new motor?
Old Mar 31, 2006 | 11:02 AM
you can get a local shop to rebuild it. What exactly happened to it? Did it overheat and blow a headgasket? If so, almost everything is prob ok, you just need a new head gasket and check if the head is warped. However, if too much coolant got into the oil, you could have locked up the crank...i.e. not good. Let me know.
Old Mar 31, 2006 | 04:16 PM
kloepfer_3's Avatar
the car not over heating at all. people said i just ned a new gasket thats all. its just old different climate changes just went old. i took off the spark plug wire cap things and i just saw oil with it. so im just gonna change the gasket and see if it cont to leak if so then i know i have a real problem
mrocke440
Nov 20, 2010 09:11 PM
digdgb
Oct 28, 2009 07:05 PM
Fasyharry
Jan 10, 2008 01:02 AM
mustang196718
Feb 12, 2007 08:48 PM
