Audi A2 This compact Audi A2 offers a lightweight aluminum structure which allows the small yet efficient engine to offer performance comparable to others in its class.
Audi A2 1.4 SE ... oil change !?
Old 05-09-2007, 05:10 PM
deltaev0's Avatar
Default Audi A2 1.4 SE ... oil change !?
Hi all, I'm the proud owner of the above, an 01 petrol with 30k miles added.
I know, I know... you must have had this one before! I have been informed that an oil & filter change will require the oil to be sucked out from above. Is this the case or can a garage do it the "normal" way? Kwikfit cannot seem to answer the q over the phone!!
Would appreciate the simple answer.
Phil
Old 07-19-2007, 10:41 PM
redmansioner's Avatar
Default RE: Audi A2 1.4 SE ... oil change !?
Check it under the engine if there are plug that can be removed to be able for you to change oil.If you see a plug,then you can pull it,just be extra carefull not to cling on the cord of the Audi oxygen sensor.
Princeargeniss
08-18-2014 02:24 AM
nc 2.7t
01-06-2006 02:54 AM
al3xino
05-13-2005 02:45 PM
Quick Reply: Audi A2 1.4 SE ... oil change !?
