00852 Fault Code
RE: 00852 Fault Code
This one took me a bit to sort through, according to the fault codes index 00852 is: - Loudspeaker(s) Front: Open Circuit.
But here's the catch, it's a false indication for my set-up. I installed RNS-E navigation and did not change the long coding to suitin 19-CAN Gatewayfor navigation present. The nav worked fine except I was getting a mis-leading fault code. Once i changed the long coding, I was good. [sm=smiley20.gif]
From => 3F3F0360074102
To => 3F3F0368074102
