06 A3 passenger door central locking faulty
Old Jun 7, 2013 | 08:16 PM
charlieenz's Avatar
Question 06 A3 passenger door central locking faulty
Hi,
My 06 A3 has developed a central locking fault whereby the passenger door doesn't unlock but all the others work fine. I can hear it trying to unlock but without success. I have manged to get the door panel outer off but there's a black rubbery looking infill with the handle wire coming through it between me and the inner workings of the door and I'm not sure how to get this off or what to look for?
Any ideas please???????
Cheers
Charlie from N.Z.
Old Jun 9, 2013 | 11:21 AM
mattymo's Avatar
Charlie, No help here but have similar issue. My rear driver side door intermittently will not lock. Have to manually lock it from the door edge. Haven't gotten the door panel off yet & my Bentley manual leaves a lot to be desired in a repair guide. Any chance of a picture to help others with what to expect in the door?
Old Jun 10, 2013 | 03:59 AM
LWNY's Avatar
there is some posting saying the solder being cracked. Here is a DIY for VW on it
VWVortex.com - Door Module Repair DIY
Old Jun 11, 2013 | 06:57 PM
charlieenz's Avatar
Default Yikes!
Hi,
The control unit looks the same but I had thought you would get through from the inside!
I hadn't fancied pulling of the outside steel panel.
Might be a job for the pro's as while I could fix the unit I'm not much of a panel beater!
Cheers
Charlie
Old Jun 12, 2013 | 12:59 AM
LWNY's Avatar
I think you can access it from the inside. If you can see the solder points, maybe it doesn't even have to be taken off.
Old Sep 25, 2013 | 01:30 AM
LWNY's Avatar
Old Sep 25, 2013 | 06:21 PM
charlieenz's Avatar
Claimed on my insurance..... All fixed.
a3turrell
Jun 4, 2023 11:15 PM
ihariff
Jan 14, 2014 08:57 AM
audiA41,8Tquatro
Jan 5, 2014 05:34 PM
burtonboarder84
Nov 26, 2008 10:22 AM
Scottjk
Mar 31, 2008 05:21 PM
