2009 A3 Terminal 30 Left Error
Hello, I've been having problems with my cooling and blower fans not turning on. I tried swapping fans (because the fan controller is in the large fan) as well as the temp sensor on the radiator outlet. Had them so figured I'd try them. Neither of those help. Then i got my hands on VCDS and did a scan. I'm getting a lot of electrical errors, as well as a terminal 30 error. I found the relay panel under the dash and swapped the relays for KL30 and horn(same part). Doing this didn't solve any problems, but it caused a bunch of errors to be thrown for the horns and dome lights. I don't really know where to look next or if I should try changing relays. I attached the most recent log I have of the vehicle. Yes, there are a bunch of other errors in here. Intercooler hose popped off before running this test and didn't realize it or clear the codes but that's fixed.
