A3 problems
Old Jun 19, 2011 | 10:54 PM
A3Pheo's Avatar
Default A3 problems
A3 1.6 2000-W reg
Not great with cars, hoping someone who knows more can give me a bit of help!
Gear change 1-2 is always very difficult, other gear changes are also quite hard to get into. Occasionally getting into any gear is impossible, I've had to turn the engine off for 5 minutes, and after this break the gears are relatively smooth. Seems a little odd if a part is worn out and then works fine. Worth bearing in mind the gears are only smooth after the problem is so bad the car wont drive and I've had leave it for 5 minutes with the engine off.
Oil depletes very quickly, I've heard this can be a problem with the gearbox casing, so perhaps a new gearbox would resolve this problem?
It's pretty expensive, so would a gearbox repair be better? If it is what could the problem be?
Much thanks for any help or feedback.
Pheo
Smokin Tubes
Feb 5, 2012 10:11 AM
mykien23
Dec 2, 2011 08:55 AM
redrhino
Oct 26, 2011 03:49 PM
commedecargons
Nov 9, 2005 06:43 PM
SamJamaica
Jun 13, 2005 02:07 AM
