A3 problems
Old Sep 26, 2006 | 08:52 AM
digital21st's Avatar
Default A3 problems
Hi
I have recently purchaced a 2001 A3 1.8 se (60,000 miles, FASH), which i must say is the best car i have driven so far in my life.
I have a few queries that i would like to ask you guys.
Firtsly, i am getting only around 20-25 miles per gallon, is this correct?
Seconly at high-ish revs there is a rattle coming from the underside.
Can anyone help
Kind Regards
Digs
Old Oct 6, 2006 | 11:57 AM
Noremac's Avatar
Default RE: A3 problems
Hi,
first post and noticed your ???'s
Had exactly the same car back in 2002, 1.8 SE, lovely car, second A3 I had bought and fell in love with it, consumption you describe is a bit on the low side, not go an answer for that but at high revs the rattling is likley to be a small coupling on the exhaust system broke loose or cracked, mine did exactly the same thing and welded bak together nicely with no problems.
Mind you 4 months later the water pump went and I was told this is a big problem with this model.
Old Oct 6, 2006 | 12:23 PM
Chef's Avatar
FYI,
On all Audis/VWs definitely change the water pump every time you replace the timing belt. It is the best preventive maintenance you can do on these cars.
Cheers!
Smokin Tubes
Feb 5, 2012 10:11 AM
mykien23
Dec 2, 2011 08:55 AM
redrhino
Oct 26, 2011 03:49 PM
commedecargons
Nov 9, 2005 06:43 PM
SamJamaica
Jun 13, 2005 02:07 AM
